Go to Post There are times when we talk as friends and joke around about things like this, but then the most important times are when he says "I'm telling you this as a mentor," no matter what it is, those moments mean a lot. - Akash Rastogi [more]
Unread 17-01-2006, 15:36
X-Zero X-Zero is offline
FRC #1203 (Pandemonium)
X-Zero is an unknown quantity at this point
Send a message via AIM to X-Zero
Belt For Fisher Price Motor
Does Anybody Know what belt is good to use on the Fisher Price Motor 00968-9002?
Unread 17-01-2006, 19:27
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Re: Belt For Fisher Price Motor
Check online to find your local Gates Rubber Power transmission products dealer. The belt is 15mm wide with a 3mm pitch and comes in a number of circumferences ( read belt length) measured in mm. I needed a belt approximately 300mm in length. They also sell the matching sprockets for the driven end of your belted drive train again with 15mm width and 3mm pitch. The motor sprocket is 16 tooth so any multiple of 16 gives the desired gear reduction ratio. I.E. 16:48 is 1:4 reduction ratio. I ordered my locally through Motion Industries and will take 5-7working days for delivery. Hope this helps out. Best wishes, LRU.
Unread 18-01-2006, 00:42
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I believe you're referring to the CIM motor. The FP motor comes with a gear, not pulley on it's output shaft.
Furthermore, I don't even see a motor with the model number that the original post references.
2001-2004: Team 100
2006-Present: Team 254
Unread 18-01-2006, 01:47
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
The new CIM motor is also a Fisher Price motor.
Unread 18-01-2006, 02:37
Cory's Avatar
AKA: Cory McBride
Yes, but it doesn't have that model number. The minibike motor is FR801-005
2001-2004: Team 100
Unread 18-01-2006, 04:22
President, VEX Robotics, Inc.
Please search before you post. I posted this last week. Look here
-Paul
Unread 18-01-2006, 11:01
Dick Linn's Avatar
no team (Synergy)
Some Powergrip GT2 belts can also be used with HTP toothed pulleys. Does anyone know if this is true with the 3 mm pitch, or only the 5 mm and up?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 18-01-2006, 15:08
\I mean the one with the pulley on it
Unread 19-01-2006, 12:34
gabrielse's Avatar
gabrielse gabrielse is offline
FRC #1748 (Lab Rats)
gabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to beholdgabrielse is a splendid one to behold
This thread helped me order some belts through a Gates distributor. Where can I get compatible pulley's for a 5/8" keyed shaft? We don't have access to a machine shop. All we have is a drill press and a band saw.
Unread 20-01-2006, 15:58
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
I found some on sdp-si.com. You have to seach for the bore size in decimal (.625)...
https://sdp-si.com/eStore/
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Unread 22-01-2006, 15:06
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
FYI ...
found a source for "HTD3" 3mm pitch belts in 15mm width. Check Quality Transmission Components. They also carry an assortment of matching pulleys and tensioners (pully width limited to 9mm ?). Their website could use some help, but hopefully a phone call will get you what you need. I don't know about their stock or delivery capabilities - hope to find out tomorrow.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Fisher Price Motor Into Drill Gearbox Chris Technical Discussion 11 21-04-2004 09:09
