Go to Post "The robot is horribly overweight. We need to delete some code" - Dumper FTW 435 [more]
Unread 18-01-2006, 06:10
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: dismanteling a chain
Both of those tools are invaluable for FIRST teams. Roller Chain is something that almost every robot will have. The chain break retails for 20.53 from McMaster (6051K15) and the chain puller retails for $17.56 (6052K14). The chain puller has to be ground on to make it fit between the links (nothing major just a little work with a file or grinder). So for about $45 to your door you can have the right tools for the job. It makes everything much easier and safer.
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Aluminum chain? Brawler006 Technical Discussion 11 24-02-2004 15:52
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
