Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 18-01-2006, 05:32
winners winners is offline
winners is an unknown quantity at this point
Question IFI_Loader Problem, please help.
Hey mates,
I tried to upload Kevin's code for the CMUCam2 on my RC, so I compiled it with the MPLab C18 Compiler, and dumped the .hex file into the RC using IFI_Loader v1.0.12 but it didnt work, I open the terminal, type t in the "To Port ->" tab then <RETURN> and nothing happens.
Then I noticed that when I upload another code to the RC, the IFI_Loader doesnt remove the older one, it just connects to the RC, tries to ERASE but doesnt, then it starts a fresh DOWNLOAD.
and if you're wondering if the Programming Led is turned to orange, yes I clicked the programming button until that led turned into orange!
I'll appreciate any help
Thanks in advance.
Unread 18-01-2006, 11:42
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: IFI_Loader Problem, please help.
I have had similar problems with IFI Loader. I can not get programs to download to the RC unless I press download wait a few seconds then put the RC into program mode. If I try putting the RC into program mode first the download will fail with a message about not being able to connect to the RC. Maybe this procedure will work for you also though our issues seem a little unrelated.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 18-01-2006, 12:25
Thanks for the help, i'm gonna try it.
are there any other suggestions?
Unread 18-01-2006, 13:18
also, what is the best version that is to be used with the FRC PIC18F8522 RC?
is it v1.0.12?
IFI_Loader v1.0.12 (zip, 1-3-2006) Must be used with the 2006 Robot Controller.
or is it just old, because on the same page just up a little bit, they wrote:-
The micro-controller inside the FRC Robot Controller is the Microchip PIC18F8520 from the PICmicroŽ microcontroller family. While this chip can be programmed in Assembly or C, the default code supplied for the user has been written in C. The user will be writing code directly at the hardware layer, but all the necessary code for integrating the micro-controller into the system has already been written by IFI and will be mostly hidden from the user.
so?
Thanks in advance.
Unread 18-01-2006, 13:25
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
is it v1.0.12?
so?
Thanks in advance.
I contacted IFI with this exact question. The answer is quite simple. 1.0.12 is compatible with the 2006 RC, backward compatible with the 2005/2004 RC and VEX as well. Bottom line, use 1.0.12 for all RC 2004 and newer. (Sorry, I can't answer this for the Edu RC)
Unread 18-01-2006, 13:30
Thanks for the help.
Well, the point is that I used IFI_Loader v1.0.12 and it didnt work.
Unread 18-01-2006, 13:33
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
The RC only executes the CMUcam2 code and the terminal display code when it is linked (by radio or tether) to the OI. Did you have the RC connected to the OI when you were doing this?
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 18-01-2006, 14:38
ahhhh, this is it then, thanks mate for the help, I'll connect the RC to the OI and then try again
thanks again!
Unread 18-01-2006, 15:19
Quote from http://www2.usfirst.org/2006comp/oth..._for_MPLAB.pdf
The Innovation First IFI_Loader v1.0.20 (Available at
http://www.innovationfirst.com/).
is that version not yet released or that I simply cant find it!?
Unread 18-01-2006, 17:54
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
No, 0.20 is wrong in that manual. .12 is the correct one.
Also, it doesn't take long for the loader to erase the existing code, so it might look like its not.
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
