Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
Unread 12-01-2006, 00:25
Electrical Engineer
Rookie Year: 1995
Re: Working with Lexan
Originally Posted by Andy Baker
...From what I recall, polycarbonate has a "blueness index". The higher the number, the more blue tint it has. Since 1963, when Dan Fox at GE invented LEXAN, this "blueness index" has gotten lower and lower...
Andy,
You have peaked my interest...
I know that you can order "optical quality" polycarb which, as I recall, is very clear. We have some at the school. I'll check tomorrow evening and see just how blue it is.
Mike
Mike Betts
As easy as 355/113...
Unread 12-01-2006, 00:27
Electrical Engineer
Rookie Year: 1995
Originally Posted by Kirk
For those teams that don't know how to tell the difference between the two, the best way to tell is take a pair of pliers and try to bend a corner. If it bends like a piece of soft aluminum its polycarbonate if it cracks or breaks its acrylic.
Kirk, et al,
I would use a sheet metal brake rather than pliers and, whichever method you use, please wear safety glasses!
Mike
Mike Betts
Unread 12-01-2006, 01:13
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by Phil Paspalas
Last season, our team used Lexan (polycarbonate) to shield the electronics from damage. We found it easy to cut, bend, de-bur, and generally pretty good stuff! But it's a pain to drill!!!!!!!!!!!!! Especially when trying to drill large holes in it to remove weight. We tryed a hole saw with poor results and regular twist drills were problematic as they get past 3/4". Any suggestions?
When doing any type of drilling in Lexan, it is best to leave the protective paper coating on (both?) sides. This prevents most cracking, and allows a cleaner cut/hole to be made.
Unread 12-01-2006, 05:15
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Originally Posted by Mike Betts
Kirk, et al,
Mike
Of course you should always wear safety glasses. I was just trying to give them a quick and dirty method to tell the difference. We have been at multiple regionals where we needed some poly carb but we have been given acrylic.
~Kirk
Unread 12-01-2006, 09:08
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Andy,
Mike
I am sure that every single person who is reading this note owns some "optical quality" polycarbonate. This style of polycarb is extruded in a clean room and the molten plastic is pushed through a filter.
Who can guess where this "optical quality" polycarbonate is used by everyone?
(15 years ago, I was a co-op engineer at GE Plastics. The Mt. Vernon, Indiana plant extruded 1,000,000 lbs. of the stuff PER DAY back then. I can still recall the sweet smell of Methylene Chloride.)
Andy B.
Unread 12-01-2006, 10:11
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
*ding*
Is it the 40 amp fuse block?
*buzz* (see reply below)
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 12-01-2006, 10:12
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Originally Posted by generalbrando
*ding*
I think he is talking about safety glasses.
Unread 12-01-2006, 11:37
Those are probably optical quality polycarbonate, but that is not what I was referring to. Not everyone owns a pair of safety glasses, but I bet that every single person between the ages of 9 and 60 owns this item.
oh, heck, I'll give the answer... it's a compact disc.
CD manufacturers seemed to be the most concerned about optical quality.
Andy B.
Unread 18-01-2006, 11:57
TheAnsweris42's Avatar
TheAnsweris42 TheAnsweris42 is offline
Team 1896 "Rules Guru"
AKA: Kenneth Casperson
FRC #1896 (Xodus)
Team Role: Webmaster
TheAnsweris42 will become famous soon enoughTheAnsweris42 will become famous soon enough
Send a message via ICQ to TheAnsweris42 Send a message via AIM to TheAnsweris42 Send a message via MSN to TheAnsweris42 Send a message via Yahoo to TheAnsweris42
Wow... thats new. Though it does make a lot of sense, now that I think about it...
Does anyone have an idea for where a good place is to get this stuff? Lexan, other polycarb, or plexi even, though I know some of you dissaprove of it
"A common mistake people make when attempting to engineer something completely foolproof is to underestimate the ingenuity of complete fools"
-Douglas Nathaniel Adams
Unread 18-01-2006, 12:44
I would use a sheet metal brake rather than pliers (to bend polycarbonate) and, whichever method you use, please wear safety glasses!
And, just to complete the circle, my prescription safety glasses have polycarbonate lenses.
Unread 18-01-2006, 13:32
FRC #0254
Your best bet is to call around to local plastics places. If all else fails theres always good ole McMaster Carr.
Unread 18-01-2006, 13:48
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
Your local Home Depot may also carry Lexan, I know ours does.
JT
229
Unread 18-01-2006, 14:52
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Many teams will not have access to these methods, but:
Lexan (polycarbonate) is easily cut using a water-jet. Plexiglas (acrylic) will probably shatter if you try to water-jet it.
Conversely, Plexiglas (acrylic) is easy to laser-cut, although it does create a stink. Lexan (polycarbonate) should not be laser-cut because its fumes are toxic.
My team has one sponsor with a water-jet machine and another with a laser-cutting machine. We found out about the differences above through some trial and error.
Richard Wallace
since 2003
Unread 18-01-2006, 15:13
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We have a 50W carbon-dioxide laser cutting table with built in ventilation, but it cannot cut polycarbonate much thicker than about an 1/8" at all -- and anything thinner than that very visibly chars around its edges.
--Madison--
...down at the Ozdust!
Unread 18-01-2006, 15:28
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
JT
229
All the Home Depots I've been in seem to carry it (at least when I've been looking). It usually in the back around the screen doors along with Acrylic and a material that strengthwise is inbetween the 2. It comes in various sizes, with the max I've seen being 3'x6'.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Sources for Delrin and Lexan stock sanddrag Technical Discussion 3 04-12-2005 00:25
Who is working on their team site over the summer? Timothy D. Ginn Website Design/Showcase 15 07-06-2005 18:47
IR Beacon/reciever not working... still... Ferazel2001 Programming 23 04-02-2004 23:30
I'm working :) Jack FIRST Scouting Network 2 03-01-2004 01:26
Whose working this summer? Frank(Aflak) Chit-Chat 20 28-05-2003 11:35
