Pro desktop 8 to 3ds max 8
I need to move a model built in pro desktop 8.0, a complicated one which was built from a lot of models attached. I wanna make an animation out of it.
Ok, look. when I import a .STL file it shows me a message: "bla bla bla design1.stl is not a valid *.STL file" This file was exported from autodesk pro desktop 8.0 in this way: File --> export --> browse --> choosing the file --> save --> ok. if you can help, pleaseeeee... Ok, now I tried a diffrent file type: *.IGS I exported it from pro desktop 8.0 in the same way and imported it in 3ds max. A simple object like a square was imported perfectly to 3dsmax 8, but when I tried importing a complicated structure like a base of a robot (which was built from several other designs which were connected to one design) it didn't import nothing. Please, if you dont know how to help, please ask people around you : ) Or you can main an answer to lm.robotica@gmail.com Tanks. Thanks a head, animation team, 1578. |
Re: Pro desktop 8 to 3ds max 8
I sometimes have the same problem. My guess would to uncomplicate the model and then fill in the gaps in 3ds max.
Just a side note, but I found it quite interesting that 3dsMAX imports .igs files much better than .dwg (AutoCAD filetype)...
| **FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! | Billfred | FIRST E-Mail Blast Archive | 0 | 22-12-2004 16:30 |
| Another 3ds max "Key" | Jack | 3D Animation and Competition | 7 | 09-05-2002 21:19 |
| Text effects in 3DS Max... | Ranma | 3D Animation and Competition | 6 | 28-02-2002 21:56 |
| Autodesk Inventor -> 3ds Max (File Format) | Adrian Wong | Inventor | 1 | 22-01-2002 23:06 |
