Re: Shaft size of Big "FP" CIM Motor
I have it on reliable source that it is 5/16" with a flat ground on one side.
Yes, that's what it appears to be. 5/16 and flat ground on 1 side. However, though it's not a big difference, because it's in the CIM family, might it be 8mm output shaft?
Anybody have a tie breaker? I just check the step file on AndyMark.biz: Andy has modelled the shaft as 8mm with a flat at distance of 3.531mm (.139") from the centerline (= 7.531mm= .269" from the OD opposite the flat to the flat). I hope this helps. Joe J. |
| IGES Model of Large CIM Motor | Madison | SolidWorks | 7 | 16-01-2006 13:27 |
| Large CIM motor specs | ryan_f | Motors | 4 | 13-01-2006 21:38 |
| using set screw or dowel pin/pin to hold on drill motor coupler thinggy | Travis Covington | Motors | 1 | 04-02-2002 03:02 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Big Shaft to Little Shaft? | Anton Abaya | Technical Discussion | 7 | 21-01-2002 19:27 |
