Shaft size of Big "FP" CIM Motor
Does anyone have the size of the output shaft for the new big fisher price cim motor after the belt sprocket is pressed off. A sketch of the length width and if there is a key would be nice.
Thanks, I don't want to press the sprocket off to find out and the motor is on the other side of town. |
Re: Shaft size of Big "FP" CIM Motor
I have it on reliable source that it is 5/16" with a flat ground on one side.
Yes, that's what it appears to be. 5/16 and flat ground on 1 side. However, though it's not a big difference, because it's in the CIM family, might it be 8mm output shaft?
Anybody have a tie breaker? I just check the step file on AndyMark.biz: Andy has modelled the shaft as 8mm with a flat at distance of 3.531mm (.139") from the centerline (= 7.531mm= .269" from the OD opposite the flat to the flat). I hope this helps. Joe J. |
| IGES Model of Large CIM Motor | Madison | SolidWorks | 7 | 16-01-2006 13:27 |
| Large CIM motor specs | ryan_f | Motors | 4 | 13-01-2006 21:38 |
| using set screw or dowel pin/pin to hold on drill motor coupler thinggy | Travis Covington | Motors | 1 | 04-02-2002 03:02 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Big Shaft to Little Shaft? | Anton Abaya | Technical Discussion | 7 | 21-01-2002 19:27 |
