Go to Post Once you know where you want to go, you can decide how you want to get there. - sciguy125 [more]
Unread 18-01-2006, 17:08
winners winners is offline
winners is an unknown quantity at this point
Exclamation data packets
I have some questions regarding CMUCam2's data packets, Type F data packet format,
Type F data packet format:
1 2 r g b r g b ... r g b r g b 2 r g b r g b ... r g b r g b 3
1 - new frame 2 - new row 3 - end of frame
RGB (CrYCb) ranges from 16 - 240
RGB (CrYCb) represents two pixels color values. Each pixel shares the red and
blue.
well, first of, "RGB (CrYCb) ranges from 16 - 240" -> is it 1 number for the whole RGB or that R has a number that ranges from 16-240 and G has another one, and R has another one?
Secondly, can anyone please explain to me what is CrYCb and how it differs from YCrCb and is there any other type?
Last thing, "RGB (CrYCb) represents two pixels color values. Each pixel shares the red and blue." -> what does it mean: "shares"?
I appreciate your time reading and helping me.
Thanks in advance.
Unread 18-01-2006, 18:25
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: data packets
Each color has a number from 16-240.
Secondly, can anyone please explain to me what is CrYCb and how it differs from YCbCr and is there any other type?
The diference is nothing but the order of the bytes that you receive. They are orcered that way so that the Chrominance (Cr being Red and Cb being Blue) and in the Red and Blue fields of the RGB. The leftover (Green) is used for the Luminance (Brightness).
Meaning the G is the only independent color. So the first pixel is RGB, the next is BGR, the next is RGB, etc.
GBRGBRGBRGBR
 BRGBRGBRG
i.e.:
GBR GBR GBR GBR
 BRG BRG BRG
Good luck!
-Joe
Unread 14-09-2006, 01:25
bballbeng bballbeng is offline
bballbeng is an unknown quantity at this point
Re: data packets
hi...which means the format of the data packet...shld be RGB BGR RGB BGR....
is that what u mean...how come the code section u posted is different??
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
