Go to Post The GDC probably took bets on how many posts they could get off of a random CAD render, and bonus points for how many people go insane from thinking about it! :yikes: - gallo26 [more]
Unread 14-01-2006, 17:43
Windward's Avatar
Windward Windward is offline
FRC #1452
Windward is an unknown quantity at this point
CMU camera search
Our camera is working, but it cannot find the green light. It just turns around randomly looking for the light. We know that it cannot be other lights, and our green light is visible. We are using Kevin Watsons most recent simple camera code. We would appreciate some help. Thank you.
Unread 14-01-2006, 20:59
rappo's Avatar
rappo rappo is offline
Drag and drop that for loop!
FRC #0696 (Circuit Breakers)
rappo is a jewel in the roughrappo is a jewel in the roughrappo is a jewel in the roughrappo is a jewel in the rough
Re: CMU camera search
Have you tried it while connected to the serial port of a computer? You can have the camera directly connected to the computer and a power supply, open the CMUCam2 program for LabView, then load the 2006 Target.cfg configuration straight onto it. If it doesn't work there, then you probably have a bigger issue on your hands. But, it's most likely the best place to start.
Team 696 Circuit Breakers
2006 LA Regional - Radio Shack Innovation in Control Award
Unread 14-01-2006, 21:04
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
My guess is you need to focus the camera.. Open up labview, keep using grab frame and rotating the lens until the picture is pretty crisp. It's possible someone thought the lens was loose and tightened it, screwing up the focus
Unread 17-01-2006, 13:05
Windward's Avatar
FRC #1452
our labview won't work. we get a message that says the serial cable (we're using a converter) isn't working or the camera doesn't have power. We don't know how to fix this and the instructions say to just "fix the error."
Unread 17-01-2006, 13:13
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
which com port is your converter. i know that with mine i am unable to connect to the camera using anything other than com1 or com2. which i was able to change in device manager. also make sure that you arent just typing comx, where x is the com port number, directly into labview. follow the format that they have and just change the x into the com port #.
for reference you can change the com port # by going to device manager->ports (COM &LPT) then double click on the converter name. click on the port settings tab, and change it to a com port that is not currently in use. for me com1 worked. and then voila labview started working. and the camera was sucessfuly recognized.
also, if your converter is not recognized in MAX you can manually change the port options so it can actually talk to the camera.
this may be stupid, but make sure that the camera is actually powered on.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 17-01-2006, 18:16
Windward's Avatar
FRC #1452
I switched the com port to COM1 and it did not change anything. What do you mean by
if your converter is not recognized in MAX you can manually change the port opitons so it can actually talk to the camera.
Unread 17-01-2006, 18:49
CmptrGk's Avatar
Programming Mentor
AKA: Dillon
like changing the baud(sp?) rate and etc. to the correct settings
Unread 17-01-2006, 19:05
Windward's Avatar
FRC #1452
according to the instructions, I already have.
Unread 17-01-2006, 22:00
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
What is the error message and error code in the error cluster on the upper right side?
If you click the arrow on the side of the serial port control, do you get a list of ports that has the port you expect in it?
Can you connect to the camera in hyper-terminal on that same port?
-Joe
Unread 17-01-2006, 23:25
ryan_f ryan_f is offline
ryan_f is an unknown quantity at this point
We kind of have the same problem. But our problem is that the camera finds the green target, but doesn't lock onto it. It just posts its coordinates (when we're watching the screen from ifi_loader) and then just keeps going on its search pattern. Is this supposed to happen or is it supposed to actually track the target?
P.S. It tracks the target fine when we use labview with the servos connected to the camera
Unread 17-01-2006, 23:35
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Depending on the version of the code, enter the tracking menu and adjust the search delay up by one, which will slow down the search and give the camera more time to let the RC know that it found the green light. Don't forget to save the new value to EEPROM when you get it dialed in. For the streamlined code, open tracking.h and look for #define SEARCH_DELAY_DEFAULT and increase the number to the right of it by one, compile the code and try it out. Repeat if necessary.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2006, 17:43
Windward's Avatar
FRC #1452
-Joe
What exactly do you mean by "hyper-terminal?"
Unread 18-01-2006, 18:34
AKA: jhersh
Meaning in Windows, go to Start >> All Programs >> Accessories >> Communications >> HyperTerminal.
It's a simple terminal application. You could also use the IFI loader terminal window.
Cheers!
-Joe
Unread 18-01-2006, 19:14
Windward's Avatar
FRC #1452
just as an update, our camera will now track green when we program it with MPLAB. We got a more updated version of the program for labview and got a new different error. It says it can't find the file. Another programmer is presently working on it. Although we got a different error, we still might get an the same error as before when we solve this present one.
Thanks for all your help, update you later.
Unread 18-01-2006, 19:21
Windward's Avatar
FRC #1452
Turns out the error from before came back.
The error says the camera might:
1- not have power
2- not connected by serial cable (using converter and haven't gotten to try hyperterminal)
3- not in correct serial port
We have checked and checked again 1 & 3 and are in the process trying hyperterminal.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
New Model Posted - 2005 CMU Camera Ed Sparks Inventor 1 04-01-2006 23:36
CMU Camera: San Jose Area Bill Gold Kit & Additional Hardware 1 11-04-2005 18:30
CMU Camera Tracking auditt241 Programming 0 03-02-2005 16:33
Easter Egg in CMU Camera Manual David Foster Programming 8 10-01-2005 03:21
