Go to Post If you don't KNOW something as fact, please do not state it as fact. - dlavery [more]
Unread 17-01-2006, 20:47
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
[solved]cmu cam woes... inability to target its objective
Allright, so we have built the light for the field (finally) and we have mounted the camera on the bracket.
we have also hooked up all the wires in their correct posistions and polarities, and the camera cn search for its target.
the only problem tho, as soon as it finds the target, it will tilt upwards. and to make theings worse, it wont pan. it is almost as if it has somehow aquired a different target, but as soon as we move the light the camera goes back to searching.
so basiacally, it will find the target, but it will always tilt upward away from the light, without any reason we can see. and yes, we have tried fillping the axes of tilt and pan. why is it doig this?
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 17-01-2006, 21:48
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Re: cmu cam woes... inability to target its objective
Are you running the camera through LabView, or through the RC?
void function(void)
  function();
Unread 17-01-2006, 23:24
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
thru the RC.
We got it to run fine in lab view, it really just doesnt like us.
i think we may have figured it out tho... i did a bit of reading and found out that the EEPROM overrrides the set values in the program if you are running the bells and whictles version.
so this means that it is probably tracking a default color or something.
i dunno... any mre obvious explanations then what we have come up with?
RPI 2012
BREAKAWAY
Unread 17-01-2006, 23:42
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by Uberbots
thru the RC.
Make sure that you didn't mount the camera upside down, load the camera code without modification and see if it works. If you're going to mount your camera upside-down, change both pan and the tilt rotation signs from the tracking menu and try it out.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2006, 18:41
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
-Kevin
EDIT: okay, nevermind. the camera was in the right way.
we reloaded the default values, and it still did not track.
may the problem be that we were using last year's camera?
ONE MORE EDIT: somehow we got it to work. a little bit of beer (lol) and saturation levels is all we really needed.
the flicker in the backgrond was confusing the camera.
RPI 2012
BREAKAWAY
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
Change CMU target on the fly kmazh Programming 3 12-01-2006 23:17
CMU Cam prosseser running hot kjhobin Programming 4 10-01-2006 21:57
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
