Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 17-01-2006, 22:13
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
LAST Wheel question
I see that a lot of teams use lawnmower wheels, and I want to know are they using plastic or metal wheels, and do most teams just drill holes to mount sprockets. Also how do lawnmower wheels hold up?
Unread 17-01-2006, 22:38
occra 23.
AKA: ryo
None #1481
Re: LAST Wheel question
we tried metal ones in OCCRA a couple years back. drilled holes to bolt the sprockets onto..... we'll just say we won't be going back to that design again.
the rubber tread just wasnt even close to grippy enough to be competitive in that sense. and we had duallys too. but then again we mightve pickesd the wrong type. ive seen many teams succeed very well with them. but i just dont like them anymore.
Unread 17-01-2006, 22:41
You don't use straight metal wheels in FIRST. If you use metal wheels, make sure you put belting around the edge as a traction device. There is a rule in Section 4 about no damaging the playing field with a traction device (and no metal on carpet). Also, I think most FIRST teams use wheelchair wheels.
Unread 17-01-2006, 22:44
AKA: Sean
I know that you can't just use metal wheels, but what wheels can you use to put conveyor belt material on. Also how can I attach caster wheels to a drive shaft?
Unread 17-01-2006, 22:47
Any you like. Metal wheels are fine with belting, Skyways are often modified with belting. I'd go with a Skyway. Grind down the tread 'till it's flat and close to the plastic. Use screws and drive them as deep as you can get them (or come up with your own unique way of attaching).
Unread 17-01-2006, 22:54
AKA: Sean
for doing six wheel drive would it be easier to use a keyed shaft or drive the wheels?
Unread 18-01-2006, 00:27
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
It's a loaded question, first determine what wheels your going to use, then your desired speed.(s) your wheels will tend to drive how you mount them, The Skyway 6 and 8 inch will only work with a 3/8" shaft unless you do some serious custom mounting. The Skyway's with an inner tube only drive with a 5/8" keyed shaft. If going with a shaft pay attention to what the shafts will be mounted in. Steel pillow blocks get heavy very fast (we built our own out of "cutting board" plastic one year) Search the forums for the Atwood gearing xls spread sheet it's a big help in picking sprockets and gears with out redoing the math every time. The wheels from IFI let you decide how you are going to go, If you are willing to spend the money. Hope this gives you some ideas.
Unread 18-01-2006, 01:55
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Our second robot used 8 inch plastic lawnmower wheels (Home Depot @ about $10 per wheel). We just drilled 3 holes and mounted the sprocket using 1/4-20 bolts and spacers. That robot just went through it's third build and those wheels still have tread on them. Even being run on asphalt several times. We've also used wheelchair casters when we needed something very light and have moved up to go-kart wheels last year.
Unread 18-01-2006, 13:51
AKA: Sean
I think I am going to try lawnmower wheels just based off of cost. Our team has a really small budget so if they work it will save us a lot of money. Are there any specific things to look for in lawnmower wheels.
Unread 18-01-2006, 13:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Colson wheels are cheap, maybe even cheaper. But you'll have to make hubs for them.
Unread 18-01-2006, 13:59
AKA: Tim Craig
If you're going to attach the sprocket to the wheel so the wheel spins on the staft (rather than firmly attaching the wheel to the shaft and driving the shaft), I'd spend the few extra dollars and make sure I got the wheels with the ball bearing hubs. I'm not sure I'd trust broaching a plastic wheel and using a key to keep it on the shaft to drive it. It probably will work as I broach plastic gears and generally they're fine but wheels can take a bit of shock. If you're going to drill through the wheel disk to attach the sprocket, don't get the wheels that have open spokes.
Unread 18-01-2006, 14:04
AKA: Sean
Yeah I'm planning on getting the ones with bearings and drilling through the wheels. How is the traction with the wheels?
Unread 18-01-2006, 14:15
AKA: Tim Craig
If you're building a 4 wheel drive robot, the traction on the 8 inch wheels we used is pretty good. Not so much grip that you can't turn relatively easily. 4 wheel drive is always a pain because of the tradeoff between traction and turning, not to mention the odometry problems when you start getting fancy.
Unread 18-01-2006, 18:38
AKA: Sean
What do people think about the skway beadlocks or the 8x2 skyway pneumatics?
Unread 18-01-2006, 18:54
AKA: Tom Cooper
The pneumatics we have both with the standard and the larger tread and tube on them. They give good grip with and the standard are pretty easy to turn, They do bounce. The larger tires have tremendous grip and take two motors a side to turn tank style. The hubs we used only drove with the 5/8" keyed shaft, they have an aluminium insert and take abuse very well. The beadlocks tend to be heavy and have a large amount of slip in all directions on carpet. On the plus side, they don't bounce
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
