Go to Post In conclusion, we can say, with reasonable certainty, that we know nothing. - Max Lobovsky [more]
Unread 18-01-2006, 19:16
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: LAST Wheel question
What pneumatic wheels did you have? They were the keyed hub correct?
Unread 18-01-2006, 19:30
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I'm going to just put this out there really quickly. Don't use the beadlocks ever on a robot. FIRST once gave them out with the kit and they just ruined a lot of teams that were forced to use one of the worst wheels(for FIRST Robots) you can find. They're big but have a small traction area, if you grind them down you'll find that they aren't tough at all and will wear away any tread you do cut into them.
The pneumatics on the other hand are great! The big 8" were used on the strongest robot my team has ever built back in 2002 and still haven't been able to top. We are trying to best it this year with tank treads but who knows, they're pretty great.
Team Website
Unread 18-01-2006, 19:40
AKA: Sean
How did you power the 8" pneumatics? You can't get them keyed so I am a little curious.
Unread 18-01-2006, 22:00
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Originally Posted by sdcantrell56
I think I am going to try lawnmower wheels just based off of cost. Our team has a really small budget so if they work it will save us a lot of money. Are there any specific things to look for in lawnmower wheels.
A couple of other things I remembered (you can't expect too much out of me before lunch ) Try to make the holes for mounting the sprocket as close to the rim of the wheel as practical as this will reduce the bearing load on the plastic disk of the wheel. Also, to spread the bolt load be sure to put flat washers on both sides of the wheel when running the bolt through the wheel disk to go through the spacer to the sprocket.
Unread 18-01-2006, 22:05
AKA: Sean
So i decided that lawnmower wheels didn't look sturdy enough. All of the ones I could find had a ton of play in the bearings whiich would probably through off the chain and sprockets.
Unread 18-01-2006, 22:22
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Beadloks make great flywheels for propelling soccer balls into goals....
Unread 22-01-2006, 00:46
SkywayWheels SkywayWheels is offline
no team (Skyway Wheels)
Team Role: Webmaster
SkywayWheels has a spectacular aura aboutSkywayWheels has a spectacular aura about
The Bead-Loks are by far the most popular wheel. They are backlogged at least a week here at the factory. ;/
Unread 22-01-2006, 11:02
AKA: Sean
Thanks everybody. I think I am just going to go with the kop wheels and grind them down and probably add conveyor tread.
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
