Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 18-01-2006, 20:46
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Re: Autonomous mode... to the max
Congrats on learning enough about neural networks (NN) to want to use them on your robot. I've done quite a bit of research with NNs and genetic algorithms (GA). The life simulator that you describe is actually a fairly common thing when studying NN and GA. Each NN is described by a sequence of DNA. The GA breeds these DNA sequences and only selects the best to continue breeding. The GA is a technique to train the NN. The main problem with controlling your robot with a NN is the size that will be needed(I will explain this later) to process all of the data that your sensors collect. The GA is a hueristic search that will eventually find the correct NN. However, a bad NN could easily cause your robot to damage itself during its training.
Since a feedforward NN basically boils down to a long polynomial function of the inputs, there is no fancy mystery about how it works. Each layer of the network will divide the range of inputs into two groups, on and off. Hundreds of layers are needed to process the hundreds of pixels from a camera.
Thats all I have time for now, but I would be happy to discuss and argue about NN, GA, and artificial intelligence.
P.S. If I havent convinced you to stop using neural networks on your robot, let me know because I would love to help you to succeed despite my predictions. Plus, I had the same dream during my first year at FIRST
Unread 18-01-2006, 22:19
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Wow.. that seems pretty complex to code.. are you sure the RC is capeable of running something like that?
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
