Go to Post FIRST doesn't just prepare you for engineering, it prepares you for life - sciguy125 [more]
Unread 18-01-2006, 20:17
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Twitching Robot
When we turn on our robot starts to twitch. The trim is set correctly and the speed controls are calibrated so I'm guessing its programming related. Any Help?
Unread 18-01-2006, 20:20
Jared Russell's Avatar
Taking a year (mostly) off
Re: Twitching Robot
Could you elaborate on what you mean by "twitch"?
Unread 18-01-2006, 20:46
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: Twitching Robot
It sounds like you have too much traction on your wheels. As you turn, your robots wheels must move sideways, and if there is too much traction on your wheels, your robot must fight against this traction, resulting in either the robot appearing to turn in "jumps" or to trip your circuit breakers, either of which could be described as "twitching".
What is your driveline like (number of wheels, dimensions, wheel sizes, wheel material/type, motors, etc)?
Zan Hecht
Unread 18-01-2006, 20:48
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
Re: Twitching Robot
or are you perhaps talking about a sudden jolt of motor movement as soon as the robot is turned on? we had a similar problem last year and were unable to find a solution.
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 18-01-2006, 20:51
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Twitching Robot
Does the "twitch" cut in and out? If it does, is there a clicking noise when it cuts out? This would indicate what ahecht said, that breakers are cutting in and out.
-Sir Francis Bacon
-Albert Einstein
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Twitching Robot
I believe the motor jolt was corrected with a RC firmware update midseason. We updated to the newest firmware, and that cleared our issue up, if I remember correctly.
Unread 18-01-2006, 21:17
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Twitching Robot
Too much caffine. Cut down on the robots intake of coffea.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 18-01-2006, 21:20
Stats's Avatar
Stats Stats is offline
What Ever it Takes
AKA: Chris Chandler
FRC #1323 (Madtown Robotics)
Stats can only hope to improve
Re: Twitching Robot
just give up its way easyer that way but seriously we had the problem of our robot jumping because our wheels were to wide that might be your problem
Life is like a bowl of fruit
every once in awile you get a tomato
and your like what the heck
thats a fricken vegetable
Unread 18-01-2006, 21:56
Re: Twitching Robot
make sure all the variables you use for motor control are initialized before the main loop runs.
at powerup all variables have random numbers - so if you created an equation like:
motorPWM = joystick Y + offset
and offset is not set to a defined number until the loop runs once, then motorPWM can be anything from 0 to 255 on the first pass through the codes main loop.
Honda's robot... Don Wright Math and Science 7 17-12-2005 13:15
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
