Go to Post The real world does not go together like an Erector set. FIRST robots should not either. - dlavery [more]
Unread 18-01-2006, 20:42
Jared Russell's Avatar
Taking a year (mostly) off
Turning a gear-tooth sensor into a quadrature output encoder
Hi,
Given the problems I've had writing working code for direction sensing with the hall-effect sensors in the kit (and apparently Kevin Watson is having the same problems), I was wondering if there was some kind of very simple circuit I could build that translates the different pulse widths into a single digital channel (if 0, forward, if 1, reverse), thus making the programming identical to that of to that of a quadrature encoder.
What about an independently-clocked counter IC? The rising edge of a pulse starts the counting, the falling edge stops it. You could then read the count line corresponding to the highest power of two that differentiates the two types - if you get zero you have a short pulse, if one you have a long one.
I.e. get an 8 bit counter (0-255). Start a count on rising edge. Use an external clock of 1MHz to increment the counter after that. Stop the clock on falling edge. Now read bit 5 (2^6 = 64). If bit 5 is 1, you have been counting for at least 64usec and you know your direction. After reading, simply reset the counter to 0.
Or, is there a way to translate from pulse widths to an analog voltage (like the analog-to-PWM conversion in the RC in reverse?)
My expertise is more in software, so someone with a mind in hardware would probably have a better idea.
Unread 18-01-2006, 20:57
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: Turning a gear-tooth sensor into a quadrature output encoder
Originally Posted by Abwehr
Hi,
If you are interested in an external part, you'd probably be best of with a small microcontroller to handle it for you. Then you can write more software.
-Joe
Unread 18-01-2006, 21:35
Yeah, I've already gone ahead and got it working on a Gumstix module, and I could always run a serial interface over to the RC if I wanted, I was just wondering whether there was some super-simple circuit I was forgetting.
All the same our team isn't going to use them, most likely, but I was curious more than anything
Unread 18-01-2006, 22:17
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Hi,
Building custom circuits out of discreet ICs is kind of passé these days. A bit of Verilog code and a small gate array, like a Xilinx Spartan 3, could easily discriminate between the two pulses. It would be very fun (for me, anyways) if teams got a FPGA demonstration board in the KOP that would allow them to easilly build such circuits.
-Kevin
Kevin Watson
http://kevin.org
Unread 18-01-2006, 22:19
-Kevin
Leave it to Kevin to bring the control system fashion police into the matter
Encoder Code Kevin Watson Programming 47 18-02-2008 12:56
Internal vs. External Gear teeth - same profile? sanddrag Technical Discussion 7 01-03-2005 10:44
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
gears Michael Leicht Inventor 12 16-09-2004 10:52
