Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 17-01-2006, 23:40
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Unhappy Cylinder Force Calculation
How much pressure is needed to pop these poof ball into the center goal with a 2" bore and 4" piston from the tip of the ramp? Is it possible? What equation can I use to find this out? HELP!
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 17-01-2006, 23:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Cylinder Force Calculation
What kind of mechanism is the cylinder affixed to? A lever arm of some sorts?
The force a clyinder puts out is just pressure times area. Area being pi*r^2 For force on the retract, subtract the cross sectional area of the rod.
Also, have you guys already ruled out a spinning wheel shooter? It is not as hard as it may seem. You can build it it one day if you were focused on it.
Unread 17-01-2006, 23:53
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
We want the ball hitting directly with piston.
Callsign: N6ARA
Unread 18-01-2006, 00:33
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
It's more an issue of flow and volume, I would suggest printing out the manual and setting up a test situation and see if you can get what you are thinking about to hit the ball fast enough and hard enough to get what you are hoping for. You may be surprised by your results.
Unread 18-01-2006, 01:01
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Thanks, I am planning on doing that as soon as I have the math down. Time to contact the math teachers and physics teacher.
Callsign: N6ARA
Unread 18-01-2006, 09:42
the equations you are looking for relate force, mass, acceleration, velocity, distance and time
you need to specify the length of the cylinder-throw, the mass of the ball, and the velocity you desire
the pressure will then fall out as the calculated force divided by the area of the face of the (circular) internal piston plate.
Force = mass times acceleration
distance = 0.5 * acceleration * time^2
velocity = acceleration * time (and you can average the velocity = final speed / 2) to get the time
remember that mass is kilograms and force is newtons. (or slugs and pounds).
something else (that has been discussed in other threads): the flow of air through the valves and hoses in the kit of parts is not that fast - probably not fast enough to laungh a ball. You will most likely need to hold the cylinder back with a release pin (a pin that blockes its forward motion) and precharge the cylinder with air, then pull the pin to fire the launcher. This means if you want a 4" throw you might need an 8" cylinder, with the release trigger pin half way down its travel.
and you might also need to take the fitting off the far end of the cylinder, to allow the air to escape without restriction.
Unread 18-01-2006, 14:20
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
We did some empirical testing with this method, and ruled it out pretty quickly. With a large diameter cylinder, you get the most force, but it takes a lot of air to fill the cylinder, so the speed is way too slow. We got much better speed with small diameter cylinders, but the force was only enough to push the ball about 4 feet.
Unread 18-01-2006, 14:24
saw the same thing a few years back. Thats why the cylinder needs to be mechanically held back while its pre-charged
then released
when you implement this way, is like an air-spring
Unread 18-01-2006, 14:38
decided to draw a diagram
1. the release pin is blocking the cylinder from extending more than half way
2. the cylinder is charged with 60PSI
3. the release pin is pulled. The business end of the cylinder has no fitting, so the low pressure air flows out freely
4. the ball is launched into tomorrow!
5. a mechanical stop prevents the end of the piston from slamming the inside end of the cylinder (not shown)
6. use a spring or surgical tubing to pull the piston back when the pressure valve is closed (not shown either)
Unread 19-01-2006, 00:44
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Say we didn't want to preload it, just have the air flow in instantly when the piston is drawn back. Then would it work?
Callsign: N6ARA
Unread 19-01-2006, 12:11
all the testing that teams have done (over the years) says no. The air cannot flow through the little openings in the solonoid valves, fittings and tubing fast enough.
Ever see the pumpkin-chuckers, the giant air cannons that launch a 10" pumpkin about a mile away? they have huge air valves that someone pulls with a foot long handle.
we dont have those valves, so you need to get the air in the cylinder first (precharge) and then pull the mechanical pin out of the way.
Unread 19-01-2006, 20:55
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
2" bore 4" stroke and a 12V solinoid with 60PSI wont work!?
Callsign: N6ARA
Unread 19-01-2006, 22:30
try it and see for yourself. The cylinder will not fill up fast enough.
I know a cylinder with 60psi slamming it back and forth looks fast, but not compaired to something like pulling a spring back and letting it go.
By precharging the cylinder, blocked half way, you are creating an air-spring. scroll back up and look at the drawing in post #9 in this thread.
Unread 19-01-2006, 22:46
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
What if it was a springloaded piston? I have seen them on McMaster?
Callsign: N6ARA
Unread 19-01-2006, 22:51
you can only use pneumatic cylinders that are on the Bimba purchase list, and none of those have internal springs
you could use an external spring, and use a cylinder to retract it.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
UpForce Guyute Technical Discussion 18 14-01-2004 23:09
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
