Go to Post the robot is never done that it just evolves less rapidly - sporno [more]
Unread 17-01-2006, 16:30
daviamp daviamp is offline
FRC #1254
daviamp will become famous soon enough
Question Gear Box Torque
What is the torque output of the gear boxes provided with the kit using two small CIM motors on each one, as well as the stall torque.
Unread 17-01-2006, 18:05
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Gear Box Torque
It depends on the wheels you're using. But if you do the 8" standard wheels that come in the kit, if my math is correct, you should have a top speed of 10.9 fps using the free speed of 5310 rpm.
(5310rpm * 14/50 * 14/50 * 21/28 * 8in/12in * 22/7[pi])/60 seconds
For torque, you should have 29 ft-lb using 2 cim motors with the stall torque of 343.4 oz-in.
(2motors * 343.4oz-in * 50/14 * 50/14 * 28/21 * [5.208 * 0.001]{to convert to ft-lb})/(8in/12in * 22/7[pi])
I hope that helps.
If my math is wrong tell me, because this is the way that I use to calculate the fps and torque for my gearbox designs.
Unread 19-01-2006, 01:01
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Gear Box Torque
This might help.
It's in the PDF, you can find a good 10 pages worth of gearbox stuff. I recommened the combined pdf.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 19-01-2006, 04:17
President, VEX Robotics, Inc.
Re: Gear Box Torque
All the answers to your questions are in the 2006 transmission manual. The gearbox output torque curve for a two motor drive is in the appendix of the manual located on the IFI website.
Unread 19-01-2006, 09:42
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Gear Box Torque
Located on this page:
http://www.ifirobotics.com/kitbot.shtml
Here is a direct link to the PDF:
http://www.ifirobotics.com/docs/2006...nual-rev-d.pdf
Given Gear box shematics rcubes85 Technical Discussion 2 14-01-2005 23:35
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
