Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 19-01-2006, 03:28
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
bending bumpers
Is it possible to soak and bend the 3/4 inch plywood to make a curved bumper? We have some large radii on the ends of our robot. Anyone try this?
Unread 19-01-2006, 07:33
Re: bending bumpers
Charlie,
You can bend dimension lumber but plywood has intentionally crossed the grain of the layers such that they won't bend. The crossed grain is what gives plywood it's strength. You can slice it almost through it thickness (1/2-1" apart) and that leaves only a few layers to bend.
Unread 19-01-2006, 09:19
GaryVoshol's Avatar
Cogito ergo arbitro
Re: bending bumpers
Don't forget the "within 10 degrees of vertical" rule.
Unread 19-01-2006, 10:02
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: bending bumpers
1/4" plywood will bend. You could glue together 3 layers of 1/4" to make the thickness of 3/4".
bumpers, a problem? 65_Xero_Huskie General Forum 27 16-01-2006 11:09
[OCCRA]: Bumpers Knights802 OCCRA Q&A 1 18-10-2005 14:39
Enough with the bumpers! archiver 2000 2 23-06-2002 22:32
Question about bumpers Randy_Ai Technical Discussion 2 23-01-2002 17:59
bumpers Martin Rules/Strategy 2 13-01-2002 21:51
