Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 19-01-2006, 08:32
Lightposter Lightposter is offline
FRC #1954
Lightposter is an unknown quantity at this point
Problem with the battery charger
Hey, my team is from israel and the charger from the FIRST kit is for 120vac, 60hz, our electronic system is based on 220vac - 50hz, how can we solve this?
P.S.
This problem is the same for the controller power source.
Please help
Unread 19-01-2006, 08:48
REVving up for a new season
FRC #2848 (All-sparks)
Re: Problem with the battery charger
you can get something like this to take care of the problem
http://www.amazon.com/o/ASIN/B000BTY...e:%20text/html
welcome to FIRST and the Chiefdelphi Community!
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 19-01-2006, 09:18
FRC #1954
Thanks for your help, we are looking for a cheaper solution though.
Unread 19-01-2006, 09:35
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
It doesn't look like there is a transformer in there - and if the charger is only rated at 60Hz 120V, then you need a transformer (converter) and not just an adapter.
The adapters are for things such as laptop power supplies and electric shaver's that will run at 220 50-60Hz but just have the wrong plug.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 19-01-2006, 10:39
P.S.
Please help
You may use any battery charger designed for lead acid or gell cell batteries up to 6 amp charging current. There should be many types available for use at 220 volts. Be sure that if you attend any regionals in the US that you bring your 120 volt charger with you. The other alternative would be to purchase a step down transformer (220 to 120) so that you can use any accessory wired for US line voltage. There should be little effect on the charger or the OI power supply when running at 50Hz. You may have a little added heating or maybe some added ripple (line related noise in the DC output)
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Dead battery! krhs_programmer Electrical 19 11-02-2005 07:31
Backup battery will not power RC steven114 Control System 13 24-01-2005 01:59
12V Battery Maintenance cbolin Electrical 16 27-12-2004 17:29
Battery charger model# ? computhief263 Programming 3 22-03-2004 13:21
