Go to Post If you can't be bothered to read the Q&A, why are you spending thousands of dollars competing? - Ian Curtis [more]
Unread 07-01-2006, 16:11
firstborn firstborn is offline
Team President
AKA: LiSeR
FRC #0842 (Falcon Robotics)
firstborn is an unknown quantity at this point
Send a message via MSN to firstborn
modifying parts?
Can you take the spring off of the BIG CIM motor? Would this be considered "modifying" parts?
·¨*·.¸¸.*Annalisa*.¸¸.·*¨·
Unread 07-01-2006, 16:25
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: modifying parts?
As it simply unscrews, yes you can. Just like you can take the transmission off the FP motor and the globe motor. You can also cut the output shafts, or make your own keyslots in the CIM shafts. The main thing you can't do is rewind the motors.
Unread 07-01-2006, 20:34
r_towle r_towle is offline
FRC #1277
r_towle is an unknown quantity at this point
Could you drill mounting hole in the new cim motor to enable use in the transmission?
I am talking about removing the spring, and pulley etc then machining the end plate so you can mount it.
Rich
Unread 07-01-2006, 20:42
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Please take these answers with a grain of salt. Unless it is posted in the 2006 FRC manual or posted directly from FIRST, all answers are unofficial.
-Michael Dessingue
Unread 18-01-2006, 18:50
dmok dmok is offline
FRC #0843
dmok is an unknown quantity at this point
Rich
We needed an automotive puller to break the end pulley (it was locktite'd or something). Just be careful machining the motor end plates: there's a lip cast into the top one to hold the shaft bearing, and machining the top totally flat removes this lip. We found out the hard way.
Unread 18-01-2006, 19:04
occra 23.
AKA: ryo
None #1481
already need a new one? jeez lol. well to our benefit i guess. wanna post up pics of the insides then?
Unread 19-01-2006, 07:44
Dmok,
You may not modify the motors provided in the kit by machining the end plates. If you want to use the large chalupa motor on the kit transmission, AndyMark makes an adapter kit. See this
http://www.andymark.biz/kit-tran-upgd.htm
See also...
<R36> So that every robot’s maximum power level is the same, the motors in the kit may not be modified in any
way, except as follows:
• The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the
physical connection of the motor to the robot and actuated part.
• The gearboxes for the Fisher-Price, and Globe motors are not considered “integral” and may be separated
from the motors. FIRST will not provide replacements for parts that fail due to modification.
• The electrical input leads on the motors may be trimmed to length as necessary.
The intent is to allow teams to modify mounting tabs and the like, not to gain a weight reduction by
potentially compromising the structural integrity of any motor. The integral mechanical and electrical system
of the motor is not to be modified.
Unread 19-01-2006, 10:55
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Al Skierkiewicz
Dmok,
You may not modify the motors provided in the kit by machining the end plates. ...
See also...
Al, While I generally agree that using the AndyMark (or some other) adapter should be the preferred method of mounting the big CIM to the kit gearbox, I cannot follow your reasoning above. It appears to me that the first exception to <R36> which you quoted above specifically permits modifying (e.g., by machining) motor end plates. How did you conclude the opposite?
Richard Wallace
since 2003
Unread 19-01-2006, 13:27
Richard,
In looking at the inspection guidelines from 2005 which are consistent with the 2006 rulebook, the end plate of the Chalupa motor(s) is not a mounting bracket, it is an integral part of the motor, unlike the van door and window motors which have obvious mounting brackets. Those motors have unusual mounting flanges with an odd position for mounting holes. It had been ruled in the past that those mounting brackets could be modified. In the case of the Chalupa in particular, the magnetic structure may be compromised by changes in the motor frame.
A red flag for me comes in response to the end of R36 should the intended modification lighten the motor or cause a problem with structural integrity.
As always, it is best to use the Q&A for official answers. I do not speak for FIRST.
Unread 19-01-2006, 13:54
... the end plate of the Chalupa motor(s) is not a mounting bracket, it is an integral part of the motor, unlike the van door and window motors which have obvious mounting brackets. Those motors have unusual mounting flanges with an odd position for mounting holes. It had been ruled in the past that those mounting brackets could be modified. In the case of the Chalupa in particular, the magnetic structure may be compromised by changes in the motor frame.
Al,
The 2005 FRC Robot Inspection Checklist Manual v. 1.2 contains some unclear guidance on p. 77 under the heading Motor Modifications, saying in one place that it is OK to modify housings and in another place that it is not OK to modify integral mechanical parts. I agree with your interpretation that in the case of the big CIM motor the endplates are integral mechanical parts, not merely elements of a housing. While machining the endplates would not compromise the magnetic structure (since the endplate material is not ferromagnetic), such machining could potentially cause a problem with structural integrity and therefore violate one of the main intents of <R36>.
I also agree with your overall conclusion that neither this thread nor any other discussion on CD can be considered authoritative; only FIRST Q & A can provide an official resolution to a question of rules interpretation. I hope that someone with an interest in this topic will submit a question there so that we get clarification of what modifications are and are not allowed for mounting the big CIM.
And let me repeat, the preferred method should be to use the AndyMark (or some other) adapter kit. This will facilitate easy replacement of a motor at an event if necessary.
Richard Wallace
since 2003
Unread 19-01-2006, 14:12
Richard,
That was one of the references I turned to when composing my previous post. It also reminded me of some of the conference call discussions on this subject during inspector training.
Unread 20-01-2006, 12:13
And the official answer is that it is allowed: http://forums.usfirst.org/showthread.php?t=311
Unread 20-01-2006, 14:35
The Q & A link above allows drilling and tapping holes to facilitate mounting.
Machining the endplate as dmok describes above clearly modified the integral mechanical system of the motor (the bearing was no longer retained) so I'd still say it violated the intent of <R36>.
Richard Wallace
since 2003
Parts Swap Jeff Waegelin CD Forum Support 10 30-08-2006 08:23
**FIRST EMAIL**/Replacement Parts Request Process Pat Fairbank FIRST E-Mail Blast Archive 0 04-01-2006 17:26
PLEASE RESPOND: NRLB & Spare Parts at Nats ngreen Championship Event 12 23-04-2004 16:06
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
