Go to Post Im ready for Christmas, then second Christmas!!!! - Raumiester2010 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-01-2006, 14:38
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Beware - transmission output shaft is not 5/8"!
Originally Posted by Mr. Van
All I can say is WHY?!?
Consider it part of the challenge. Sure it would be easier if they were 5/8" but part of the challenge of FRC is to work with what you have in the time your given. This is just another one of those real world simulations. Consider that in the rest of the world 16mm may be more common than our 5/8". Maybe this is a hint from FIRST to start moving toward the global metric standard. It is a bit odd though to have a 16mm bore on a 3/8" (#35) chain sprocket.
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
