Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
View Poll Results: should a height violation while extending count?
yes 31 79.49%
no 2 5.13%
only if it is a gross violation 5 12.82%
extending out? 1 2.56%
Voters: 39. You may not vote on this poll
Unread 19-01-2006, 17:27
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
will a height violation while extending the robot to the 5' size count against the team?
i mean like if you have a folded robot and when it unfolds the top goes above the 5' size in a diagonal position while falling, would we lose points?
Unread 19-01-2006, 17:30
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
Re: height violation while extending
Do you mean the size check or when the game starts?
Unread 19-01-2006, 17:32
gondorf's Avatar
what I mean is that say you have a robot that is 5 feet tall. however it is set so that the top will be pushed up and over on the sides to make it into a 5' size on all sides. when it folds out if the tops of the falling parts temporarily go over 5' to allow for diagonal falling. should this count as a height violation?
i mean when the match starts
Unread 19-01-2006, 17:33
focus fanatic's Avatar
focus fanatic focus fanatic is offline
FRC #1561
focus fanatic is infamous around these parts
i dont think you should be punished but only if ur under the 5' limit once finished unfolding
The square root of pie is equal to the sum of the whole (Quiz: how many nerds does it take to mock this for me to take it off?)
Unread 19-01-2006, 17:36
AKA: Doug
No, I wouldn't think so. You would problem have better luck asking a seasoned ref.
Unread 19-01-2006, 17:38
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
i believe intentionally falling over (a la 67) is illegal in this years game
<G17> ROBOT Orientation - ROBOTs must maintain their vertical orientation with respect to their starting position throughout the match. ROBOTs may not intentionally tip over onto one of their initially vertical sides and operate with this side parallel to the ground. If a ROBOT is accidentally or intentionally tipped over onto its side, it cannot score any balls in any goals from this orientation.
Unread 19-01-2006, 17:43
gondorf's Avatar
no that isnt what i mean at all. i mean having the wheels on the bottom but having it 5'tall at the beginning but after the match starts sort of spreading out so instead of being 28*38*60 you are 60*60*36 or something. using a motor or pneumatics mechanism to shove the top out.
actually it is sort of falling inside the robot and spreading out without any wheels ever leaving the ground.
just think of jelly. it is tall then when it sits it spreads out into a shorter but wider shape
edit: none of the ones extending out are vertical at the beginning. all the sides that are on the outside when extended are internal at the beginning.
sounds sort of like turning your robot inside out and flattening it like a pancake.
Unread 19-01-2006, 17:46
BSEE, MSEE, JD
AKA: employed
i would run it by the GDC on the FIRST Q&A, but i would imagine they are probably not going to allow it (but that is just a guess on my part)
Unread 19-01-2006, 17:48
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
R08: Once a match begins, robots may extend horizontally beyond the 28-inch x 38-inch starting size under their own power, up to a limit of 60 inches in either horizontal cardinal dimension. The robot may not exceed the 60-inch height restriction at any time during the match. In other words, after the start of the match the robot may expand up to a maximum volume of 60 inches by 60 inches by 60 inches. The one exception to the height restriction is provided in Rule <R13>. Any restraints (elastic bands, springs, etc.) that are used to maintain starting size must remain attached to the robot for the duration of the match.
(emphasis mine)
At no point may your robot be taller than 60". If you have a mechanism that causes your robot to be taller than that temporarily while you expand, then I think it's pretty clear that it would violate R08.
Unread 19-01-2006, 22:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
This issue is currently a "grey issue" as defined purely by the rulebook.
<G16> Maximum Height - A ROBOT may not extend above 60” above the floor or the ALLIANCE
PLATFORM in a stable configuration at any time during a match. Each violation shall result in a penalty
of 5 points per occurrence or 5 points per ball shot or ball blocked during the occurrence, whichever is
greater. ROBOTs designed to violate this rule are not allowed. For example, a ROBOT that extends a
blocking device in front of the center goal will be disqualified. Transient conditions that may cause a
diagonal dimension of the robot to momentarily exceed the 60” height restriction – such as during a tipover
or when climbing onto the ALLIANCE PLATFORM – are not subject to this rule. The one
exception to the height restriction is provided in rule <R13> (flag rule).
What is defined as a "Stable Configuation"?
Is that just when you are being acted upon by other robots, field, or game elements that you are unstable, or are unfolding or midway points of motion unstable?
This is definately a question for the Q&A
Unread 19-01-2006, 23:03
Software Engineer
Rookie Year: 1995
Interesting. R8 seems to clearly disallow any extension above 60" but G16 makes it appear that it's OK at certain times. However, I think the last sentence of G16 reveals the intent: that if your robot is tilted (because of climbing the ramp, or if it's falling over) then it is not in a stable configuration and the 60" rule does not apply. It doesn't seem to me like it was meant for allowing items on the robot that are designed to be above 60" temporarily, but that's just my interpretation. As always, the GDC interpretation is the only one that matters
Unread 19-01-2006, 23:07
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
<G16> Maximum Height - A ROBOT may not extend above 60” above the floor or the ALLIANCE PLATFORM in a stable configuration at any time during a match. Each violation shall result in a penalty of 5 points per occurrence or 5 points per ball shot or ball blocked during the occurrence, whichever is greater. ROBOTs designed to violate this rule are not allowed. For example, a ROBOT that extends a blocking device in front of the center goal will be disqualified. Transient conditions that may cause a diagonal dimension of the robot to momentarily exceed the 60” height restriction – such as during a tipover or when climbing onto the ALLIANCE PLATFORM – are not subject to this rule. The one exception to the height restriction is provided in rule <R13> (flag rule).
The bolded section is the key. If the extension is DESIGNED to exceed the 60" height limit while it deploys, then count on racking up those violation points every match. Since the intial problem statement above indicates that this is the case ("it is set so that the top will be pushed up and over on the sides to make it into a 5' size on all sides. When it folds out if the tops of the falling parts temporarily go over 5' to allow for diagonal falling.") it would seem a safe bet that this will be considered a violation.
-dave
Unread 19-01-2006, 23:51
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
-dave
This is exactly what I was thinking. My suggestion would be to design away from anything that could potentially break the 60" plane or make the extension short enough or at a lesser degree that it would not break the plane. But then again... is it stable as it moves up and out?
Unread 20-01-2006, 08:33
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I interpret the rule and the "stable" terminology as meaning controlled. If the robot is moving parts on its own and breaks the 60" plane, that would be controlled movement and as part of the design of the robot, the 60" plane is broken, which results in a penalty. "Unstable", in my eyes, is an instance in which an external force is acting on the robot (another robot, a game piece) and causing it to change its orientation. So, the short answer is yes, if at any time during the match a robot exceeds 60" UNLESS it is caused by an external force, there should be a penalty. The thing about it is the refs would have to have a trained eye to look out for these things, and some infractions may not be caught. I look for the GP in each team to make sure the robot and its design don't break the rules.
Hi!
Height of basket Max Brin Technical Discussion 1 12-01-2006 14:43
Dimension Wanted - BOM Caster: floor to top plate surface height kmcclary Kit & Additional Hardware 2 28-01-2004 12:02
Ball Tee height Dave... Rules/Strategy 2 11-01-2004 01:29
Railing height archiver 2000 1 24-06-2002 00:17
height questions Team461 Off-Season Events 3 29-10-2001 21:51
