Go to Post There is no shame in playing the best match you can play. - sanddrag [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
  #61   Spotlight this post!
Unread 16-01-2006, 15:29
Re: 10 Balls per second?
Originally Posted by amateurrobotguy
FAKE, I got PROOF it is a Fake. Check out the attached pic to explain it all or read and/or read explanation. Look at the bottom of the goal. watch as the balls to 'throuth the goal right', as they cross through the goal and WE KNOW that the balls go into the goal, disappear as they are blocked from view by the bottom of the ring and reappear in the gap and then disappear again when they go behind the stand. However, they are being caught by a guy standing IN FRONT of the goal into a garbage can. NOT POSSIBLE. TOTAL FAKE.
I watched the video - I see what you mean.
the plywood that the guy with the garbage can is standing infront of is a crate or something in the background - its not attached to the goal.
It does look confusing because you cannot measure depth in a 2D video like this, and the crate and the goal are the same color plywood. If it was shot from the side you would see:
Crate______Guy with can______Goal_______<balls going left____Guy by launcher.
the simplist explaination in this case is the correct one.
  #62   Spotlight this post!
Unread 16-01-2006, 15:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Here's my take on it. Whether is is a robot or not, that is 10 balls, going through one hole, without any missing, in a very short period of time. Quite impressive I must say.
  #63   Spotlight this post!
Unread 16-01-2006, 15:44
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Yes, it would make sense if it is a crate back there. However, there still isn't any proof that anything they could put on a robot will do this. And the sound is still puzzling me, count how many wooshes you hear during launching. Can someone split this and get a sound print picture to count them? Versus how many balls are launched, I think I count 7 wooshes but only 5 balls. What is that voice saying in the end, why is there a crash at the end of the launching?
I suspect they have some laucher set up with a tube full of 10 balls. Turn it on and have a kid push down on the tower of balls and quickly force them all into the launcher part.
The sound sucks in the first video it does 2 different tones it starts boop, boop, boop, then goes beep, beep, beeep. The second half sounds like drums and the first almost like a xylophone. I suspect the first was sped up and reversed. And also look at the balls going in, wouldn't a mechanical launcher to it more uniformly instead of having 2 go in a the same time?
I quit FRC over 2 years ago (more if you're reading this past 2010).
  #64   Spotlight this post!
Unread 16-01-2006, 15:52
jebzter jebzter is offline
AKA: Justin Beardsley
FRC #0968 (Robotics Alliance of West Covina)
jebzter is an unknown quantity at this point
the launcher is 100% real. I know this because i made it. it is roughly based on a pitching machine. And it is possible to have a version mounted to a robot.
See yall in competiton.
  #65   Spotlight this post!
Unread 16-01-2006, 15:57
But in the second vidoe, you only launched 5 balls in my guestimated .7 seconds, and I don't quite trust the first video enough. Ok, the launcher is real, but does it 100% launch that many balls?
  #66   Spotlight this post!
Unread 16-01-2006, 16:06
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Settle Down folks.
#1, if it is not a fake, very impressive, but... ...it is not terribly different than the Rage Team showed with their videos.
#2, if it is a fake, so what? ... ....it is not terribly different than the Rage Team showed with their videos.
#3, let's all try to keep from liable and name calling... ...it is not terribly different than those So and So's over at Rage Team showed with their faked videos - JUST KIDDING!!!
#4 settle down, seriously.
Joe J.
Team #88, TJ2
  #67   Spotlight this post!
Unread 16-01-2006, 17:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Even if it isn't a robot doing it, it proves it can be done. And therefore, there is a high probability that a robot can be built to do it.
So what if it's a fake, it's THEIR time they are using to make a fake video, and its YOUR time you are wasting arguing over it. If it's fake, they can't use it in the competition against you anyway, so get over it...
  #68   Spotlight this post!
Unread 16-01-2006, 18:57
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Rage's device is more impressive than ours, bottom line. What is really funny is that they posted their videos in the Robot Showcase forum, and I posted this in the Rumor Mill. The forum heading has to lead you to SOME conclusions...
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
  #69   Spotlight this post!
Unread 16-01-2006, 19:38
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
We have something to be just about that quick...you will all see it soon enough.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
  #70   Spotlight this post!
Unread 16-01-2006, 20:29
MrBlack298's Avatar
MrBlack298 MrBlack298 is offline
Everyone wants to be Mr. Black...
AKA: Jack
FRC #0177 (Bobcats)
MrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura about
ya, rage's video is wicked sick. And I think I figured out how it works. I'll give you a hint: look at the fan in a leaf blower.
Triple Threat!!!
You should listen to The Monotones
  #71   Spotlight this post!
Unread 16-01-2006, 21:48
Jeremy's Avatar
Jeremy Jeremy is offline
AKA: Jeremy Medendorp
FRC #0968 (RAWC Robotics Alliance of West Covina)
Jeremy is on a distinguished road
Send a message via AIM to Jeremy Send a message via MSN to Jeremy
All I got to say Is be afraid, be very afraid
Jeremy Medendorp
College Mentor
______________________________
2003- Arizona Regional Winners
2003- Southern California Regional Finalist
2004- Southern California Regional Semi-Finalist
2004- National Quarter-Finalist Newton Division
2005- Southern California Regional Finalist
  #72   Spotlight this post!
Unread 18-01-2006, 22:57
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Team 1327's first try got under 3 seconds. Still need more control for aim, but proves that it is possible to get close to 1 second.
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
  #73   Spotlight this post!
Unread 19-01-2006, 17:53
FTtyler's Avatar
FTtyler FTtyler is offline
FRC #1561 (Purple Ducks)
FTtyler is an unknown quantity at this point
Hey that is good! We can only shoot 5 balls per second How did u do it???
  #74   Spotlight this post!
Unread 19-01-2006, 19:49
1robotmom's Avatar
1robotmom 1robotmom is offline
mentor team768,1464,1727
AKA: Linda Niznik
FRC #1464
1robotmom is an unknown quantity at this point
Wow! Good work, guys!
  #75   Spotlight this post!
Unread 20-01-2006, 14:31
Mentor Iron Giants
AKA: David Kolberg
We are still working on our mount for the robot, but this prototypye used two wheels powered by using one stage of the standard transmision and the CIM805-001 (small CIM) motors. this provides more than enough power and requires the controller to "throttle down" the power to keep the wheels spinning at the allowed speed. The wheels are 12" pneumatics from a previous years robot. Now on to making the mounts for the robot. From our testing it appears to be important how the balls enter the shooter as to how straight the ball will shoot.
Dave
David Kolberg
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
