Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 19-01-2006, 19:23
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Camera never finds target, stays at "Searching..."
We finally got our robot/camera all set up tonight. I managed to calibrate the camera using LabVIEW, and it tracks consistently through that. However, when I load Kevin's code onto the RC it stays in the "Searching..." mode. I edited all the options in tracking.h, DEBUG goes through all 18 states and then into searching.
Any idea on whats wrong?
Thanks,
Mike
EDIT: I would try the serial port diagnostics program, but our school doesn't give us wireless access, so I can't get it on my programming laptop
http://www.mikesorrenti.com/
Unread 19-01-2006, 19:34
Re: Camera never finds target, stays at "Searching..."
We got the same error.
Solution: give up.
Unread 19-01-2006, 19:45
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
try using camera_s or whatever (the simplified version) we had the same problem but the no bells and wistles version solved our problem
KK4KQO
http://voltair.us
Unread 19-01-2006, 19:55
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
I had that problem.. the solution was to roll back to the default values that came with the code. From there, once it works, you can slowly start tweaking things one at a time to make it work a little better.
Go try the default code with no changes.
Unread 19-01-2006, 20:19
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I wonder if the camera would work better if they made it track an infrared light source and the put a visible light filter over the lens...
An offseason project, I guess.
Unread 19-01-2006, 20:37
Mike's Avatar
AKA: Mike Sorrenti
Thanks for the help...
We are using the simplified version.
Sadly, I have to work tomorrow night (boo!) so I won't be able to go into robotics and try out the rolling back idea. I might get access on Saturday, so I'll post then if/when I have a problem.
Thats probably a good idea in theory Greg, but I couldn't imagine how much IR interference there would be. I wasn't around in ye olden days (04) to program with the IR beacons, but from what I've heard such small things as the auto-focus on a camera (which uses IR to sense the distance) can cause interference.
Unread 19-01-2006, 20:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Thanks,
Mike
The solution it to just use the default values included in the code. You should literally be able to load the copy of camera.hex from the zip file and have it work out of the box.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2006, 20:44
FRC #2429
Solution: give up.
Couldn't you be a bit more constructive?
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2006, 20:48
EricH EricH is online now
Well, if we're talking FLL, we had to set all the cameras in the room to manual focus when we were using the robot. If we didn't, the robot would do whatever it felt like. So, it is true that a camera's auto focus can cause interference quite easily; I'm just not sure of the extent in FIRST.
Unread 19-01-2006, 21:12
Mike's Avatar
AKA: Mike Sorrenti
-Kevin
Ahh, I'll try that first thing when I get bot access. I thought we had to use the LabVIEW program to get the values for the code.
So what's the point of the LabVIEW program?
Unread 19-01-2006, 21:41
Rookie Year: 1234
It lets you fine tune your tracking stuff. I found I needed to enable the noise filter a little, and change some color values.
If you change the config to everything that labview works, stuff stops working.
I think I changed the stuff for Track_Color a little, and increased NF_DEFAULT to 3. Past that, not much I need to do
Unread 19-01-2006, 22:43
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
-Kevin
And that it did Mr. Watson. This year Team 1541 will definately be using the camera!
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 22-01-2006, 12:47
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Mike,
Our team used LabVIEW to come up with the correct calibration values just like you did. Similarly, when we went to use the bells and whistles code on the robot (the EduRC actually) it seemed to lose track of what we had told it. The key is that the camera code by default puts the camera BACK into RGB even if you did your calibration values. This isn't a simple switch in camera.h, turns out it's actually a bit in the COMA register (the bit ID escapes me at the moment but it is documented).
Once we figured that out, we had our EduRC bot with the bells and whistles code following our GLOD* with no more issues, based on the 'highly calibrated' Labview values.
-Eric
*GLOD=Green Light Of Doom
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
