Go to Post it is easy. you will have to define "easy" in your own terms. - Mike Martus [more]
View Poll Results: did you use the kitbot?
yes 82 31.18%
no 138 52.47%
kitbot? 43 16.35%
Voters: 263. You may not vote on this poll
  #76   Spotlight this post!
Unread 18-01-2006, 01:16
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: how far have you gotten on your robot?
We have our 'bot fully designed. We'll be using kitbot chassis, and should have a ball launcher and chassis built by the end of the weekend. All the rest of our fabrication is on hold pending receipt of parts from various suppliers. I estimate two weeks from Sat. untill completion, giving us two weeks of drive time.
We may order additional parts and create a practice bot after ship date.0
Programming...progresses. I should have a functional auton. by monday, and a stellar one by ship.
www.metalmoose.com
  #77   Spotlight this post!
Unread 18-01-2006, 09:08
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
yeah the prototype above uses most of last years transmissions parts and also there are gonna be alot more improvements but this was just proof of concept. the final version is gonna be with more rpms and with a belt drive to conserve space.
  #78   Spotlight this post!
Unread 18-01-2006, 20:44
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
A little update as to how far we have gotten...
we have integrated physics caluculations into the code, so that the shooter can actually track the goal.
and it scores 9/10 of the shots.
oh boy a great victory for the programming team tongight! we have autonomous shooting!
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #79   Spotlight this post!
Unread 18-01-2006, 20:46
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
we have only got the electronics started and the field built
  #80   Spotlight this post!
Unread 18-01-2006, 20:57
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
Originally Posted by Eric Scheuing
That was EO's, right? What happened with that?
umm...there was not enough pressure on the ball, so it only went about 2 feet...literally.
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
  #81   Spotlight this post!
Unread 18-01-2006, 22:02
Dulaney1727 Dulaney1727 is offline
AKA: Scott G
FRC #1727
Dulaney1727 is an unknown quantity at this point
Send a message via AIM to Dulaney1727
Question Re: how far have you gotten on your robot?
I was wondering my Rookie Team was far behind. My teacher insists that we are right on schedule but it is hard to tell, knowing that there is so much to do and so little time left.
We have experimented on the devices to try and discover a system that would effectively shoot the 7.5 inch ball. We discovered that pneamatics would not be powerful enough and using springs was good idea but also did not work out so well in the end. We also tried using a pinball machine design, where a "hammer" would hit behind the ball and launch it forwards, but it again turned out not to be powerful enough. We are now trying to build a system with wheels and a motor to shoot the ball out similar to softball machine at batting cages.
For the electrical stuff, we have laid out the most of the electronics and created the circuits and have screwed everything down to the plywood.
We have built the chasis for the robot and started to play around with the camera, but are running into some technical difficulty.
We have yet to look into a hopper system and a system for picking up loose balls.
Thanks
Scott
  #82   Spotlight this post!
Unread 19-01-2006, 07:00
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Originally Posted by gondorf
good point.
unfortunutely we arent able to get mor alum so we are stuck using kitbot.
we are still working on trying to make the motors work and i just found out that wheels cant be chemically treater for traction.
my school has problems with their robot
which brings up another question: have you had problems with your robot/prototype? i mean something like blowing up or smoking. our motors started to smoke
we had that problem with our gearboxes too...i figured out that the lock washer you put on the shaft to hold on the pinion was binding with the other gears...so we removed the lockwasher and just used the newer set screws that were included in the parts bag... try that and they shouldnt smoke.
  #83   Spotlight this post!
Unread 19-01-2006, 07:19
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
So far I've been programming like a mad man to get the camera up and running. I've gotten it to drive one of our old bots toward the goal and stop at a certain distance from it. Our ball shooter prototyping is done now and we'll begin working on the real one soon. I'm not too sure how progress is coming on our chassis but its atleast a day behind schedule I'll be starting to work on an inertial navigation system today
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
  #84   Spotlight this post!
Unread 19-01-2006, 07:48
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
my team has so far completed a entire mock up and working model of a old baseball pitching machine. so far we have been able to easily through the balls at 30-35 feet. we also have our camera pretty much worked and programmed out. so we are on a good course. now if we could only get the real robot to preform just as well we might actually win something. i will hope to post pics. of our mock up for the benefit of others. until have a great time building. and remember to "aim low"!!!!!!!!!!
  #85   Spotlight this post!
Unread 19-01-2006, 09:51
This happened to some of us last year, too. We tried trimming the circlip down so that it didn't rub, but ended up just taking it off. We went through the season without a problem. In fact, we just stripped the transmissions for the first time since we assembled them last January, and they were perfect inside -- no visible wear. These are nice transmissions (although our left-hand transmission still growls just like it did a year ago).
  #86   Spotlight this post!
Unread 19-01-2006, 12:58
Ellery's Avatar Unsung FIRST Hero
Ellery Ellery is offline
Working on my 10 month old robot...
AKA: Ellery
no team (X-CATS - on Sabbatical)
Ellery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond reputeEllery has a reputation beyond repute
Send a message via AIM to Ellery Send a message via Yahoo to Ellery
Well what worked for our team last year was to have a fully functional prototype by the 2nd Saturday. At this agressive schedule we would be able to improve the final build and have time for our drivers to practice. I would suggest to any rookie team to remember the "KISS" terminology and use what's given to you as much as possible to keep you on a productive schedule.
Xerox Sr. Systems Engineer
Other jobs: Retired X-CATS Team Leader, Inaugural FLR MC and plain ol' nice guy
Team# 191 X-CATS - Est.1992 (www.x-cats.org)
"We don't just build robots we build people..."
  #87   Spotlight this post!
Unread 19-01-2006, 13:37
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
So far everything is working well. We're a little behind so we should have a completely functioning robot by Monday night.
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
  #88   Spotlight this post!
Unread 19-01-2006, 14:39
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
what's wrong with the kitbot frame?
we used it last year and played heavy defence, i saw no major wear.
(pictures are located at our website )
so far we have:
-a prototype shooter working on a large cim motor, but it's not fast enough and it could only score a goal from about 12 feet away and the max distance is a bit more than 30 feet. , it needs improvement.
-we built full size feild parts, center goal corner goals and ramp.
-we're arguing on design
-our custom wheels are being made, they'll be welded and ready to go by next week since we can't weld it with out mig welser, we'll need a tig welder.
  #89   Spotlight this post!
Unread 19-01-2006, 15:02
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I don't know if anyone did this, but if you watch the assembly video from 2005 it says that the set screws will bind, and that you need to replace them with the included replacements...
  #90   Spotlight this post!
Unread 19-01-2006, 19:47
jesusfreakmths's Avatar
jesusfreakmths jesusfreakmths is offline
AKA: Jonathan
FRC #1778
jesusfreakmths will become famous soon enough
Send a message via AIM to jesusfreakmths
So far we have a basic design. we are currently trying to get our robot to move around with out ruining anything. lol.
Has anyone had there speed controller (Victor 884) start smoking and melt?
Anyways we are a little behind, gut are amazed at what we have gotten done so far since we are just a rookie team.
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
