Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
  #61   Spotlight this post!
Unread 17-01-2006, 19:55
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Re: Animation Previews
So which one is better maya or 3ds max, never used maya here so can't compare. Also, I heard most video games and 3D movie makers like pixar and disney use 3DS MAX.
Hear about the cannibal that passed his brother in the forest.
  #62   Spotlight this post!
Unread 17-01-2006, 19:58
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Originally Posted by Brindza
Thanks
and do you know why they arent allowing maya and also how they are going to enforce it?
arent there converters?
Autodesk supplies FIRST with the program 3DS MAX. The awards and competition for animations is done through autodesk. Thats why its called Autodesk Vizualiztion competition, or whatever. They want teams to use their product.
  #63   Spotlight this post!
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
they aren't allowing it because until recently maya was a competing program. It's the Autodesk award, not the Alias award. I gues they just want to push their own product. But, maybe next year, cuz alias was just bought by Autodesk.
I said a while ago, they can't enforce it, but that doesn't mean you should do it.
EDIT: DAGGIT! you beat me to it while i was typing!
  #64   Spotlight this post!
Unread 17-01-2006, 20:10
Mr.Fraggs's Avatar
Mr.Fraggs Mr.Fraggs is offline
Script0r
Mr.Fraggs will become famous soon enough
Send a message via AIM to Mr.Fraggs Send a message via MSN to Mr.Fraggs
I like better maya cause its easier to use for me(i like visual boxy and im a visual learner)thers some cool texturing things and hair is awsome in maya. like you can paint directly onto an object in maya rather then texturing it if you want more info IM me
  #65   Spotlight this post!
Unread 17-01-2006, 21:10
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
I don't know if max 8 come with them, but there are a lot of premade materials in the materials library. i have mine left over from max 6, and just copy the materials over every time i update. if you don;t have raytrace libraries 1 and 2, pm me and i can email them to you. they'll help a lot.
don't worry, this stuff is legal as it is part of 3dsmax6 that went out 2 years ago.
ok, first off, my version of 8 doesn't work, and i only have version 7. so if it is possible i'd like to restrict it to just 7. i will try what you have said so far and see how far i will get. thanks.
  #66   Spotlight this post!
Unread 17-01-2006, 21:25
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
Are you having problems with the network licensing of 3DS Max 8? Heres a link on how to get it to work:
http://www.chiefdelphi.com/forums/sh...hlight=3ds+max
  #67   Spotlight this post!
Unread 17-01-2006, 21:40
animator1's Avatar
Animator
Team Role: Animator
ok, thanks for the tip with the glass/transparency effect. Now i was wondering how to get proper lighting. When i do it, it looks like it is over lit, too white, and not realistic. How do i start?
  #68   Spotlight this post!
Unread 17-01-2006, 22:43
White_Orpheus's Avatar
White_Orpheus White_Orpheus is offline
Woot for Aphex Twin!
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
White_Orpheus will become famous soon enoughWhite_Orpheus will become famous soon enough
Send a message via AIM to White_Orpheus
Admittedly, I'm terrible at lighting, but typically skylighting will do the trick for a simple scene. It's very possible to come up with better looking solutions, but nothing is as easy as the skylight. Just place one of those babies in the scene, and click on "final gather" under indirect illumination in the render panel. The downside is that the render time is pretty long, and you *need* to be using the mental ray renderer.
Team 253
2004 Silicon Valley AVA Winner
  #69   Spotlight this post!
Unread 17-01-2006, 22:48
animator1's Avatar
Animator
Team Role: Animator
um..ok, that would be for an outdoor scene though wouldn't it? what if i wanted to have a light for an indoor scene such as an overhead ceiling light for a room?
  #70   Spotlight this post!
Unread 18-01-2006, 10:36
Brindza's Avatar
Brindza Brindza is offline
AKA: Jordan
FRC #0888 (Robotiators)
Team Role: Operator
Brindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the roughBrindza is a jewel in the rough
Send a message via AIM to Brindza
i like maya better, but it might be just because im used to it.
i feel like the hotkeys in 3dmax are all over the place and hard to get to.
and ive been looking for about an hour now and cant figure out how to make my 3dmax have just the perspective mode and not the 4 screen system
  #71   Spotlight this post!
Unread 18-01-2006, 14:35
Animator
Team Role: Animator
the most likely reason for getting you scene washed out is because your lights' intensities are too high ot too close to your object. try lowering the intensity of the lights, or use less of them.
Another good concept for lighting is "three point lighting". this is exactly what it sounds like. just put three omni lights in an equilateral triangle, slightly skewed, centered on your object. then, pick which light is the one you want to be your main light, or the one that represents the lightbulb/sun/lightsource. set the intensities to .8, .6 and .4 or some numbers like that, depending on what looks best. Make sure the one you decided is your primary light has the highest intensity. Lastly, turn off all shadows for every light that is not your primary light.
if you have a small room, you can get away with only 1 or 2 lights. If you use mental ray, there are a few tricks you can use, like the emmitter object options etc, but that gets complicated quickly.
Down in the lower right corner of the screen are 8 buttons, one is a hand, one is a rotate thingy, etc. i can't remember which one, but one of those 8 buttons maximizes the viewport you have selected. to set it back, just click the same button again.
  #72   Spotlight this post!
Unread 18-01-2006, 15:51
Corporat's Avatar
Corporat Corporat is offline
Mama mia, that'sa one spicy robot!
AKA: Anthony R
FRC #1676 (Pascack Pioneers)
Team Role: Animator
Corporat will become famous soon enoughCorporat will become famous soon enough
Send a message via AIM to Corporat Send a message via Yahoo to Corporat
All of our team has no previous experience 3ds Max that I know of, but things are coming along smoothly. Maybe I or one of them will post some pictures of our work.
  #73   Spotlight this post!
Unread 18-01-2006, 16:44
mehul mehul is offline
no team (Technotics)
Team Role: Animator
mehul is an unknown quantity at this point
easier way is select the prospective view and hit "alt+w" this should maximise the prospective view, then if u ever want to change to front hit-F...... the hotkeys are on that little brouseure that was included in the package or use google
  #74   Spotlight this post!
Unread 19-01-2006, 19:55
Some Random Guy's Avatar
Some Random Guy Some Random Guy is offline
None #0201 (FEDS)
Some Random Guy is an unknown quantity at this point
Hey, could we try to keep this thread on topic? I don't mean to be rude, but this is the thread for animation previews, so let's see some more. I'd show some of ours, but we don't have much solid material right now.
  #75   Spotlight this post!
Unread 19-01-2006, 19:57
animator1's Avatar
Animator
Team Role: Animator
yes, sorry about that, i would show something soon. possibly a weeks time.
Animation Previews 2005 klyngbaek 3D Animation and Competition 13 21-02-2005 20:14
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
