Go to Post CD makes FIRST an infinitely better place. - lemiant [more]
Unread 12-01-2006, 10:05
1574aviad's Avatar
1574aviad 1574aviad is offline
Aviad T. Rom
AKA: Aviad Rom
FRC #1574 (MisCar)
1574aviad is on a distinguished road
Send a message via ICQ to 1574aviad Send a message via MSN to 1574aviad
Wiring problem
As our electronics&electricity sub-team started to connect the Power distrabution we found that there were no connectors for the Ground stud.
Does anyone know where can we find one?
Should it be at the First kit or should be buy it seperately?
Thanks in Advance.
Aviad. Team #1574
I heart FIRST
2005- Israeli regional champions
2006-Israeli regional- champion alliance, innovation in control award, entrepreneurship award, woody flowers award
Championship event-14th on Curie, backup #4 on elimination
1574 Rocks
i turned into a mentor
Unread 12-01-2006, 10:21
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Re: Wiring problem
It will save a lot of energy/weight to use last years fuse block which encompassed everything. Though it will cost $80 to get a new one as you can't use parts from last year's robot, it'll be worth it, trust me.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 12-01-2006, 13:06
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Wiring problem
Go and buy connectors that you need. The kit supplies some ring terminals for the #6 gauge wire. For other gauges you will have to supply your own. It is very important to use connectors sized for the gauge wire you are attaching. A bad crimp can come loose or be a source of high resistance.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 12-01-2006, 13:20
Electrical Engineer
Rookie Year: 1995
Re: Wiring problem
In your kit, you have 6AWG ring lug connectors (light blue insulator) and bare copper SLU screw connectors for 6AWG wire. Both came in the "Terminal Supply" bag.
If you do not have the proper crimp tool for the ring lug connectors, please use the screw connectors.
Crimping connectors is more of an art than most people realize. A bad crimp on a high current wire will cause you numerous problems down th road.
If you do not have an electrical engineer as a mentor on your team, ask your teacher if your school has an electrical maintenance person on their staff (almost all schools do). If you ask politely, I'm sure that he (or she) will attend a meeting and show you the proper way to crimp power connectors.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 12-01-2006, 14:01
Re: Wiring problem
Thanks in Advance.
Aviad. Team #1574
You have found out by now that almost none of the connectors have a large enough mounting hole to fit the grounding stud. Most hardware stores and home centers will have what you need. Try to obtain connectors that have the right size mounting hole but do not achieve that by sacrificing the overall size. The connctors in the electrical bag (in my opinion) do not have enough material to provide a reasonable attachment point or provide a low enough insertion resistance. If you use this type of connector please make sure you anchor the wires securely so that the connector will not fail during competition.
Unread 12-01-2006, 15:16
nirty's Avatar
nirty nirty is offline
FRC #1574
nirty is an unknown quantity at this point
Re: Wiring problem
we found are lost connections in the mass so thank you all for the help.
we just need to work more organized to find are parts.
Unread 12-01-2006, 17:04
want2modmygt's Avatar
want2modmygt want2modmygt is offline
AKA: Will
#0494 (Team RUSH 27 (2 years) -----> Goodrich Martians)
Team Role: Electrical
want2modmygt is on a distinguished road
Re: Wiring problem
Regards,
Mike
My freshman year, when I learned proper crimping methods, to help ensure a snug fit, i was taught that it's also considered a "sport."
www.cardomain.com/id/redbeauty2006
my 1997 GAGT
Unread 13-01-2006, 12:13
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Re: Wiring problem
As I understand the rules, you CAN re-use COTS items from last year as long as they are still available. However, when accounting for your robots cost, you must use the current purchase price (treat them as if you bought them new this year).
Go ahead and re-use that breaker panel if it suits your needs. Just remember that it is to be used in addition to those included this year.
See Robot Rules <R22>, <R24>, and <R43>.
Steve
Unread 15-01-2006, 21:29
Rick Thornbro Rick Thornbro is offline
#0217 (ThunderChickens)
Rick Thornbro will become famous soon enoughRick Thornbro will become famous soon enough
Re: Wiring problem
A great number of electrical problems are caused by the badly installed crimp connectors. I like to crimp and solder connectors on to the wire. The old belt and spenders approach. Beats having a dead robot.
Unread 15-01-2006, 22:13
Sscamatt's Avatar
Sscamatt Sscamatt is offline
AKA: Matt Syska
FRC #0195 (Cyber Knights)
Sscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud ofSscamatt has much to be proud of
Send a message via AIM to Sscamatt
Re: Wiring problem
Steve
Team Update #2 allows the 2005 Breaker Panel to be used instead of the breaker panels and maxi fuse block in the 2006 KOP.
Link: http://www2.usfirst.org/2006comp/Upd..._update_02.htm
2006 Championship Finalist, Thanks 25 + 968!
2006 Newton Division Winner
2006 International Innovation In Control Award
2006 Radio Shack Innovation in Control Award, UTC Regional
RIT Class of 2011
Unread 19-01-2006, 19:05
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
Re: Wiring problem
So this year must we use the ground stud or can we make our own ground buss ?
I'm proud to be a...
Unread 19-01-2006, 20:22
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Wiring problem
<R54>
The EX18-12 Battery, the Main 120 Amp Circuit Breaker, and the Circuit Breaker distribution panels must be connected as shown in the 2006 ( or optionally) as in the 2005 diagrams shown below.
According to <R54> you must follow the power distribution displayed in the 2006 FRC P.D. diagram, which shows the negative paths branched through the included terminal ground stud.
-Michael Dessingue
Unread 19-01-2006, 20:41
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Wiring problem
Alternatively, you can use the 2005 FRC P.D. diagram. This topic was discussed extensively in an earlier thread and resolved by FIRST in Team Update #2.
Richard Wallace
since 2003
Unread 19-01-2006, 22:35
Re: Wiring problem
if you have the right equipment crimping & soldering the terminals on the 6awg wire will let you sleep better at night
Unread 20-01-2006, 07:39
anna~marie's Avatar
misses FIRST
Re: Wiring problem
thanks
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
My Wall Caught On Fire!---A Classic *Mangia* Aignam Chit-Chat 10 03-09-2004 03:27
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
