Go to Post There will inevitably be enough unintentional failure in any endeavor we take on that adding intentional failure on top of that seems unnecessary. - Jared Russell [more]
Unread 19-01-2006, 21:36
VanZuiden VanZuiden is offline
Rookie team
FRC #1736
VanZuiden is an unknown quantity at this point
Exclamation Driving omni-directional wheels
Our team currently has AndyMark aluminum 8' omni wheels. Our plan consist of have a 4 wheel drive system, driving high friction wheels in back and the omnis in front. When preparing to mount the wheels we need to know a few things:
Where to find "hubs" for the wheel to place bearings in to.
also, since we plan to drive these wheels where can we find a 28 touth sprocket to drive. then as well how do we go about assembling all of this?
any help is appreciated,
thanks
Unread 19-01-2006, 21:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Driving omni-directional wheels
Well, you can get a 1/2" ID 1.125 OD flanged bearing either from Small Parts (p/n BRF-08) or from AndyMark. I'm not too sold on the idea of putting that wheel on just one bearing though. Here's that might work. Make some standoffs, (round bar stock with hole in the middle) maybe about 1" long and put like 6 of them on the wheel (every other hole). You might be able to get by with nylon ones from the hardware store. Then, buy a sprocket big enough that you can put the same hole pattern in it. Also, bore out the center to 1.125" If you do not have access to machine tools, the hole pattern can be done with a drill press and a bit of careful planning and measuring but the 1.125 bore might need to be machined. Bolt the sprocket to the wheel with the standoffs in between. Put a bearing in the wheel. Put a bearing in the sprocket. Call it done.
Another thing you could do, if the bolt circle on the wheel is too big for the sprocket of your liking, would be to run a live axle. Make some 1/8" steel or titanium plates with something like a 1/2" hole and an 1/8" keyway. You can lasercut the whole thing, or you can cut the plate some other way and brach the keyway (or dremel if you are desperate). Bolt one plate to each side of the wheel. Use a 1/2" keyed axle and a 1/2" keyed sprocket.
If you have access to a machine shop, you can make some really nice aluminum hubs for the wheel.
So buy sprockets, www.mcmaster.com and www.sdp-si.com are good places to start your search.
EDIT: AndyMark sells a wheel hub 1/2" ID with 1/8" key for $16
Unread 19-01-2006, 22:02
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Sounds like you guys are off to a great start for a rookie team. I'm sure someobdy else who knows more about omni-wheels will post and help you out, but I just want to say don't be afraid to simply try stuff. That's what your first year is all about. Then again, a lot can be learned from the people on this site.
Unread 19-01-2006, 22:54
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
We just did this tonight so I know it works. TO save a little $$$, we bought one hub per wheel from AndyMark, and put it on backwards. That way, the drive shaft is supported in the middle of the wheel, as opposed to having a hub on either side. We threw on some sprockets, some collars, and threw them between two base mounted bearings and it works like a dream!
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 19-01-2006, 22:59
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
thanks
http://www.phxhs.k12.az.us/education...88&pagecat=139
this link to our website shows what we did
Faridodin "Fredi" Lajvardi KD7WKD
Omni Wheels Survey Ryan F. Technical Discussion 44 04-05-2004 13:24
Omni Directional Wheels Will Seymour General Forum 3 11-01-2003 12:43
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
