Go to Post I would say that you are not an engineer until you've both obtained the aforementioned peice of paper AND done something with your tumescent engineers forebrain. - phrontist [more]
Unread 19-01-2006, 22:00
krigby krigby is offline
FRC #1734
krigby is an unknown quantity at this point
CMUCam Servos not Responding on Robot
Well, We've read the code inside and out. We've read every thread, dealt with power issues, calibrated it in LabView, and have finally gotten it to recognize the target on the robot using the RC. However, we can't get the servos to move. We have loaded the no frills camera.hex file. In the terminal window it shows the processor commanding the servos but they won't move. We have them connected to the default PMW sources PMW1 and PMW2. Any ideas.
Kevin - Team 1734
Kevin Rigby
Unread 19-01-2006, 22:12
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Re: CMUCam Servos not Responding on Robot
Maybe you need to switch power mode to external servo power? Backup battery fully charged? Those are just some suggestions.
www.sabrerobotics.com
Unread 19-01-2006, 22:15
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Basic questions:
1. You've got both leds on the camera lit up?
2. You've tested the serial link between camera and bot?
3. If you manually turn the camera, does it report seeing the light?
4. Have you plugged in your backup battery to actually power the servos (unlikely to be the problem if the camera is powered, since both get their power from the same place)
Unread 19-01-2006, 22:27
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Kevin - Team 1734
Kevin Rigby
I have an idea, but it will take some explaining. I posted this information already once today in this thread, but so far no reply. If you did follow Kevin's instructions exactly, then you copied the camera, tracking, terminal and serial port .c and .h files into a copy of the default code. You also will have edited the appropriate files with the corresponding # include statements. So far so good. But, did you notice that in Kevin's code, he had commented out the user_routines.c/Default_Routine call. This would prevent mapping of the PWM 1 & 2 to their corresponding joystick inputs. Well... if you did follow Kevin's instructions, then you copied all these files into a clean copy of the default code which does not comment out the call to Default_Routine and the PWM mapping takes place after the cameras code and overwrites the values with 127. Now please do not mistake this as a bash on Kevin, far from it! Kevin is AWESOME . What I am saying is that a complete familiarity with how all these pieces of code fit together is crucial.
The alternative is to just load the camera.hex file Kevin included with his code and it should work. Then, just tweak the values in the terminal window.
Unread 19-01-2006, 22:52
Jared Russell's Avatar
Taking a year (mostly) off
One word: 7.2 volt backup battery. Ok, three words and a number
The camera itself actually uses power from the main battery via an analog input port. The servos get it from the PWM connector via the backup battery.
Unread 19-01-2006, 23:34
iBheat's Avatar
iBheat iBheat is offline
FRC #0418 (Lasa Robotics)
iBheat is on a distinguished road
I believe the camera is supposed to be hooked up to a PWM output on the RC.
Though I do believe people have powered the camera off of the +5V analog input because the backup battery does not last too long when the camera is connected to a PWM port since the PWM port is powered by the backup battery and the +5V analog input is powered by the main 12V battery.
Unread 20-01-2006, 11:13
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
You say you've dealt with power issues, but it still sounds like your backup battery is dead or not connected. (The camera is supposed to take its power from a PWM output on the RC, and the backup battery is where the PWMs get their power.)
Unread 20-01-2006, 23:19
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
We've had the same problems as the original poster of this thread. I'm looking forward to trying out the solution Kevin handed to us. Seems almost too easy.
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
Public apology from myself (Team 830) Don Wright Rules/Strategy 13 14-03-2004 22:02
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
