Go to Post When I had "shop" back in High School they emphazied safety to the fullest extreme. I'm glad they did, I still have a full set of 7 fingers........ - Stillen [more]
Unread 19-01-2006, 22:15
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Re: Speed Ramping with Deadzone
All I did last year was add a small deadzone - I forget if I scaled down the other values outside of it to zero or not - and implement a parabolic or sinusoidal curve instead of a linear one. The drivers liked the sinusoidal one the best, but there was a lot of room for improvement.
Try experimenting with different curves, and adding joystick buttons to increase or decrease the speed by some factor is not a bad idea. Make sure your drivers know that this process is mostly trial and error, so it's up to them to communicate which system works best for them.
Electronic Speed Controllers for DC Motor Spindle Robotics Education and Curriculum 12 23-04-2005 09:18
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
