Go to Post My students like to win, so I'll stick to enabling that. - sdcantrell56 [more]
Unread 19-01-2006, 04:41
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
Smile serial port interface
Hi
im using the FRC tTL serial port to connect another controller to my robot
and i dont know how to read the serial Data from the other controller...
can Anyone help my with an example on how to read/write from the serial TTL port?
thanks
Unread 19-01-2006, 15:48
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: serial port interface
Originally Posted by AMIRAM
Hi
thanks
If you use the serial port driver at http://kevin.org/frc, it's very easy to send and receive data from either of the serial ports. Have a look at the process_data_from_master_up() function in serial_port_diagnostics.zip/user_routines.c for an example that moves data from/to both serial ports.
-Kevin
Kevin Watson
http://kevin.org
Unread 19-01-2006, 20:12
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Unhappy Re: serial port interface
Can you use the serial port 1 to connect to another 18 series pic eventhough that port has a RS232 chip interfaced to connect to PC.
Can't use serial port 2 since the camera is using it.
How many sensors can you put on the FRC before you start pushing it(including Camera)?
Thanks.
Unread 19-01-2006, 22:11
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Yep, but you'll have to use another level shifter to get from RS232 back to TTL on your other pic.
Unread 19-01-2006, 22:15
6600gt's Avatar
AKA: Lohit
So have like a external MAX232 wired to the pic?
Unread 20-01-2006, 09:09
pclements's Avatar
pclements pclements is offline
AKA: Patrick
FRC #1254 (Entropy)
pclements is an unknown quantity at this point
Send a message via Yahoo to pclements
why would you use a different controller if the other one works just fine?
Unread 20-01-2006, 09:26
becuse the sensor that i want to use is slow and give me the data in pulse width and if ill be witing for the pulse ,the program wont send the Data evry 26mS and wont work....
Unread 20-01-2006, 09:33
6600gt's Avatar
AKA: Lohit
Thats the thing i don't how far you can push the RC. I want quite a bit of accuracy form both the accelerometer and a the gyro. I would also like to keep track of the RPM's of the spinning wheel in the shooter to adjust the power as required.
Now with the camera and these sensors and trig functions, you could easily push the RC to its limits, I think.
Unread 20-01-2006, 11:20
fowlerm's Avatar
AKA: Matthew Fowler
You could connect the CMUcam to the program port since it already uses RS232, and then connect your other pic to the TTL port directly. If you're concerned about runnning a whole DB9 serial cable to the camera you could just buy a DB9 connector and replace one end of a pwm cable with the DB9. The CMUcam already has a PWM-style 3-pin connector for RS232 Tx, Rx, and ground (which is all you need).
Unread 20-01-2006, 12:00
FRC #2429
Offloading this extra work onto another microcontroller is a great idea.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2006, 14:45
6600gt's Avatar
AKA: Lohit
I can use your code for the pic, Kevin?
Unread 20-01-2006, 16:20
FRC #2429
There's only two things I care about: 1) The code not be posted on other publicly viewable websites, FTP sites, CVS, etc. 2) The code be used for educational purposes only (i.e., not used to make a profit for someone). If this is for your FRC robot, you're encouraged to use the code anyway you see fit. I've been hoping someone would do what you intend to do. If you get stuck, I'll be happy to help you out if I can.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2006, 18:29
6600gt's Avatar
AKA: Lohit
-Kevin
It is for FRC and i might use it for my personal work or research on the pics but nothing to do with commercial use.
Is there anything really important that I have to modify to make the serial port driver, adc, gyro, and accelerometer code work with a 18F4XX series pic?Other than the usual registers and pins.
Would a CAN bus connection to the TLL port work? What type of serial connection does your serial port drive control?USART?
Unread 22-01-2006, 02:03
is ther any rule about connecting another microcontroller to the FRC??
Unread 22-01-2006, 02:12
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
It's the same rules as any other circuit.
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
