Re: Gear Tooth Sensor Question
http://www2.usfirst.org/2006comp/Spe...oth_Sensor.pdf
Make sure your sensor is oriented the way it appears in the pictures, and make sure the air gap is less than a few millimeters. |
| Gear tooth sensor vs. Optical Encoders | Avarik | Programming | 7 | 17-01-2006 10:18 |
| LabView Gear Tooth Sensor Code | SkiRacer | LabView and Data Acquisition | 2 | 17-01-2006 03:53 |
| Accelerometer vs Gear Tooth Sensors | zdeswarte | Electrical | 4 | 22-01-2005 15:35 |
| gears | Michael Leicht | Inventor | 12 | 16-09-2004 10:52 |
| Coupling the drill motor with out the 15 tooth gear | Chopper_Dave | Motors | 1 | 17-01-2004 01:06 |
