#19
Re: Beware - transmission output shaft is not 5/8"!
how easy would it be to extend the drive shaft output? our team is planning on using a six wheel drive but without using the skyway wheels. rather some modified off the shelf wheels. the problem is they are 2 inches wide at the widest point (the tread is only 1 inch) and the easiest way to line them up is to extend the output. any help?
| diameter of transmission output shaft | sj31419 | Electrical | 5 | 17-02-2005 22:09 |
| supplier for 5/8" shaft | david.clark | Kit & Additional Hardware | 2 | 17-01-2004 18:13 |
| Cutting the output shaft | Kevin A | Technical Discussion | 2 | 18-02-2003 01:47 |
| Securing hex shaft to drill output | D. Gregory | Technical Discussion | 6 | 24-01-2003 14:05 |
