Go to Post Or Dave could be messing with your head. - Daniel_LaFleur [more]
Unread 18-01-2006, 12:05
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
Question Sensitivity Wheels - help please
hi, 'sup doods?
I have a problem in setting the program code for the wheels.
In my program code I've already set the wheels but there is a problem.
The Joystick is too Sensitive! When I pull it full froward the robot just flies!!!
Can someone please give me the code for Sensitivity?
Unread 18-01-2006, 12:13
Re: Sensitivity Wheels - help please
if you want full forward to go half as fast as it is now, divide the joystick readying by two
since the center (off) reading is 128, you need to add 64 to the result to get off back to 128
joystick := (joystick / 2) + 64
if you want it even slower, divide by 4 and add 96 to get zero back to 128.
Something to consider: if your robot is way too fast with the motors running full speed, you might need to gear down your drivetrain (or use smaller wheels). This will bring down your top end, and give your robot more pushing and climbing power.
Unread 18-01-2006, 20:15
Jared Russell's Avatar
Taking a year (mostly) off
You might also find it useful to change the characteristics of the joystick vs. speed curve.
Basically, make it so that if you push the joystick within zero and halfway (for example), it gives you up to 1/2 of your max speed, then from halfway to full forward it gives you the rest.
Example:
#define SENSITIVITY_TOLERANCE 179 /* play with this value */
#define SENSITIVITY_DIVISOR 2 /* and this one too */
#define SENSITIVITY_EDGE (SENSITIVITY_TOLERANCE-127)/SENSITIVITY_DIVIDER+127
int reverse_p1_y = 0;
if( p1_y < 127 )
     p1_y = 254-p1_y;
     reverse_p1_y = 1;
if( p1_y < SENSITIVITY_TOLERANCE )
     p1_y = (p1_y - 127 )/SENSITIVITY_DIVISOR + 127;
else
     p1_y = SENSITIVITY_EDGE + (p1_y-SENSITIVITY_TOLERANCE)*(254-SENSITIVITY_EDGE)/(254-SENSITIVITY_TOLERANCE);
if( reverse_p1_y )
     p1_y = 254 - p1_y;
The result is that you can move your robot at max speed, but it is more controllable at lower speeds.
Unread 18-01-2006, 22:35
I think you meant to say if you push it up to half way it gives you up to 1/4 speed, and above that the outputs increase twice as fast.
the default RC code gives you half speed at half-stick, right?
Unread 18-01-2006, 22:42
Yeah, that's what I meant.
Unread 18-01-2006, 23:01
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Originally Posted by naor52
hi, 'sup doods?
The output from the Victor speed controllers is very nonlinear with respect to the input value. You're at around 90% output at half the input range. What you want to do is insert a transfer function between the joystick input and the PWM setting to the speed controllers. With this you can linearize the response of the motors with respect to the joystick or even tailor it to have "sweet spots" for sensitive control where you want it, usually at the low end.
Unread 20-01-2006, 09:13
pclements's Avatar
pclements pclements is offline
AKA: Patrick
FRC #1254 (Entropy)
pclements is an unknown quantity at this point
Send a message via Yahoo to pclements
Don't pull the joystick foward all the way, it's like a car.
Getting A Bot To Turn Andrew Blair Technical Discussion 20 16-10-2005 23:49
Who Likes Wheels? Rob Technical Discussion 22 06-05-2004 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
