Go to Post Wait, crap... totally forgot that I needed to build an intake. :eek: - Andrew Schreiber [more]
  #46   Spotlight this post!
Unread 14-01-2006, 23:17
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
Re: 2006 Autonomous Disappointment
Now, I have a question.
We're a rookie team this year and we probably won't use the camera as our programmers are very green and a launching mechanism is beyond the scope of our mechanical team. What are other options for the autonomous period? I have heard suggestions about a spiraling drive pattern, just to bump into other bots to screw them up. Would that be effective? or would the bumpings be inconsequential?
Thanks
  #47   Spotlight this post!
Unread 14-01-2006, 23:21
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Thanks
As far as the camera goes, it's quite possible they could get it working.. out of the box the code will search for and lock onto a target
If you drive around randomly in auto. with the intent of running into other robots, I would worry about damage to your robot or someone elses. (Although we had our robot run full speed across the field last year, and right into the other wall) But I don't think driving around like that would do much..
  #48   Spotlight this post!
Unread 14-01-2006, 23:41
pez1959's Avatar
Cap'n Patty
AKA: Patrick
Well I know that there are specific rules about ramming, but as far as the robot goes, I think we are pretty sure that we are going to ignore the top goals and just go for the sides. However, we aren't looking at a "garbage-can-dump-bot" like in the game animation, so the auton period seems useless to us.
Basically we decided to learn the CMU cam during the off season and get familiar with it to prepare for next year's competition.
  #49   Spotlight this post!
Unread 14-01-2006, 23:55
We're a rookie team this year and we probably won't use the camera ...
Thanks
the problem with just driving around is you may drive into your own alliance partner, who is trying to score ten balls in the center goal.
If nothing else, try for a dead reckoning approach to blocking your opponents goal, ie: drive forward two seconds, turn left for 1/2 second, drive forward for 2 seconds - see where your robot ends up, then tweak the timing to get the robot more or less where you want it on the field. then have it just sit there
or you could take the same approach and try to score one or two balls in the side goals. Even one point can be the difference between winning auton mode, if your alliance partners can score points as well
who knows, you might have matches in which none of your opponents can score any points in auton. Then one point would be all you need!
  #50   Spotlight this post!
Unread 15-01-2006, 14:20
MichaelGoldfarb MichaelGoldfarb is offline
AKA: Goldfarb
FRC #0312 (Heatwave)
MichaelGoldfarb is an unknown quantity at this point
Send a message via AIM to MichaelGoldfarb Send a message via MSN to MichaelGoldfarb
Originally Posted by TimCraig
And everyone would have the opportunity to score some points during autonomous. There would be a wider range of scores during autonomous. And it would me that teams OTHER than the top teams could hope to score meaningfully.
Every team needs to start from somewhere, if it's the bottom rankings than you have to work your way up. We were all rookies at some point and the only way to get better is to take on the challenging.
I'm crazy!
  #51   Spotlight this post!
Unread 15-01-2006, 14:56
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Just to clarify, dead reckoning is not the practice of turning on a motor for a given time. That is just a pre-timed sequence.
Dead reckoning is using sensors on your robot to figure out its speed and direction and integrating to maintain an approximate location and heading. This is a widely misused term in FIRST... I'm not sure why.
See wikipedia.
Cheers!
-Joe
  #52   Spotlight this post!
Unread 15-01-2006, 16:19
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
See wikipedia.
Cheers!
-Joe
I was under the impression dead reckoning was running without feedback, such as sensors, and just blindly driving, whether based on timers or loop counts or just setting your motors to a wide turn and leaving it.
"dead reckoning
n 1: an estimate based on little or no information [syn: guess,
guesswork, guessing, shot]
2: navigation without the aid of celestial observations"
http://dict.die.net/dead%20reckoning/ google turned this up, not sure of the validity, so I'm not really sure. Anybody have any other sources?
Matt Krass
  #53   Spotlight this post!
Unread 15-01-2006, 17:04
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Many of the LEGO Mindstorms books I have read refer to rotation sensors/encoders as a form of dead reckoning. The way I would define it would be anything which is based off of assumptions on how you started. (IE, you have to be in a certain spot and track yourself the entire time.) Basically, "I reckin' I'm right about thar."
  #54   Spotlight this post!
Unread 15-01-2006, 17:19
Matt Krass's Avatar
AKA: Dark Ages
Alright then, I suppose that is the correct definition, but I still think dead reckoning can include running "blind" (Without sensors) its still assumption based.
Matt Krass
  #55   Spotlight this post!
Unread 15-01-2006, 17:30
dead reckoning: any mode of navigation in which you are likely to end up dead :^)
the real defining difference is navigation with no outside references. Looking at your speedometer and driving for 30mph for 5 minutes, or running a boat engine as fast as it can go for 10 minutes, then turning left, going for 5 minutes...
if you use a compass, or GPS, or sensors that detect outside waypoints (lighthouses for example, or light beacons....) then you are not dead reckoning.
Even the use of a compass is in between, because it can tell you direction, but not distance - so with a compass you only know which way your are pointing, not where you are (and not really which way you are moving, because a compass in water cannot indicate the effects of current, wind and tides).
Im not sure that having feedback sensors on your wheels, or using a timer (counting clock pulses) makes a difference. Your wheels can slip, the tires can wear, another robot could be pushing you backwards while your wheels are spinning forwards, so I dont see how a wheel sensor is any more accurate or reliable than going by applied motor power and timer clicks?
  #56   Spotlight this post!
Unread 20-01-2006, 09:27
pclements's Avatar
pclements pclements is offline
AKA: Patrick
FRC #1254 (Entropy)
pclements is an unknown quantity at this point
Send a message via Yahoo to pclements
Cool Re: 2006 Autonomous Disappointment
I'm sort of disappointed that the autonomous phase was cut to only 10 seconds this year. Finally, we get a processor that's reasonably capable, we've had a couple of years to develop some experience with the PIC processors, and instead of increasing the time so we can really show off, we get our time cut. Programming the autonomous phase is one of the more difficult and time consuming parts of robot development, I think cutting back the time seems to denegrate its importance. I was hoping for at least 20 seconds if not 30.
Well, Look on the bright side, you can program the robot and have it go streight, with any luck it might even be able to soot in the hoop, ah heck, what am i thinking, thats bull only giving us 10 seconds, and my freind says hi, an you can use the autonomous mode next year .
2006 game poll #3 (mor or less emphasis on autonomous) dhitchco Rumor Mill 3 19-11-2005 19:45
2006 game poll #4 (type of "sensing" in autonomous mode) dhitchco Rumor Mill 1 18-11-2005 12:27
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
