Go to Post Robots that don't obey the laws of physics will be checked for alien technology and magic. - Greg McKaskle [more]
Unread 20-01-2006, 10:16
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Cylinder Force Calculation
Originally Posted by KenWittlief
you are not allowed to disassemble the cylinders or modify them in any way - but you can build them into a mechanism that alters its behavior (adding an external spring-return, or an external trigger release.
No matter what the bore and stroke of the cylinder is, the air flow is controlled (restricted) by the valves and fittings and hoses. There is nothing you can do to the cylinder to make air flow through the valves faster.
And you cannot use other valves, or modify the ones in the KOP.
By mod i meant like change sizes, I know you cant mess with the parts. I just want to make less volume to cover, to it fills up faster, but I guess that doesn't work.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
UpForce Guyute Technical Discussion 18 14-01-2004 23:09
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
