Go to Post Saying that something cannot be done, is always good inspiration for someone to find a way to do it. - Josh Hambright [more]
Unread 20-01-2006, 00:55
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Cylinder Force Calculation
Originally Posted by KenWittlief
you can only use pneumatic cylinders that are on the Bimba purchase list, and none of those have internal springs
you could use an external spring, and use a cylinder to retract it.
Say if I modified the bore and stroke length? Would that make a difference? a smaller volume means it will get filled up fast right?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 20-01-2006, 08:40
you are not allowed to disassemble the cylinders or modify them in any way - but you can build them into a mechanism that alters its behavior (adding an external spring-return, or an external trigger release.
No matter what the bore and stroke of the cylinder is, the air flow is controlled (restricted) by the valves and fittings and hoses. There is nothing you can do to the cylinder to make air flow through the valves faster.
And you cannot use other valves, or modify the ones in the KOP.
Unread 20-01-2006, 10:16
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
By mod i meant like change sizes, I know you cant mess with the parts. I just want to make less volume to cover, to it fills up faster, but I guess that doesn't work.
Callsign: N6ARA
Unread 20-01-2006, 10:32
a smaller diameter cylinder will fill up faster, but it will have less force on its pushrod. The force a cylinder generates is equal to the surface area of its internal; piston plate times the pressure of the air you feed it with.
So, yes, a smaller diameter cylinder will pressurize faster, but the trade-off is less output force.
Is there some reason why you dont want to implement the release-trigger like I drew in the diagram? its probably the easiest way to make a pneumatic shooter.
Unread 20-01-2006, 23:43
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
I think a lever would be a better idea. Where a bar has a pivot on one end, then have the piston in the middle then the other end of the bar hits the ball.
Callsign: N6ARA
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Mulit-postioning with pnuematics this year? KenWittlief Pneumatics 101 01-02-2005 21:54
UpForce Guyute Technical Discussion 18 14-01-2004 23:09
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
