Go to Post Once you have a lathe you'll wonder how you ever got through life without one. - Wayne TenBrink [more]
View Poll Results: did you use the kitbot?
yes 82 31.18%
no 138 52.47%
kitbot? 43 16.35%
Voters: 263. You may not vote on this poll
  #91   Spotlight this post!
Unread 19-01-2006, 19:52
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: how far have you gotten on your robot?
we were about to have the basic chasis running, BUT we had to do a major over haul of the chasis due to lack of ground clearance and we should be running by tomorrow, and will be able to finish on schedule.
  #92   Spotlight this post!
Unread 19-01-2006, 19:53
Originally Posted by jesusfreakmths
Has anyone had there speed controller (Victor 884) start smoking and melt?
Anyways we are a little behind, gut are amazed at what we have gotten done so far since we are just a rookie team.
We haven't fried one (that I know about) since last year. Was the smoke white or black?
  #93   Spotlight this post!
Unread 19-01-2006, 20:16
MrBlack298's Avatar
MrBlack298 MrBlack298 is offline
Everyone wants to be Mr. Black...
AKA: Jack
FRC #0177 (Bobcats)
MrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura aboutMrBlack298 has a spectacular aura about
Originally Posted by robochik52
umm...there was not enough pressure on the ball, so it only went about 2 feet...literally.
thats unfortunate. that design looked promising. hoepfully we can modify it saturday.
Triple Threat!!!
You should listen to The Monotones
  #94   Spotlight this post!
Unread 19-01-2006, 21:53
Andrew Blair's Avatar
FRC #0306 (CRT)
Originally Posted by Nuttyman54
I don't know if anyone did this, but if you watch the assembly video from 2005 it says that the set screws will bind, and that you need to replace them with the included replacements...
Yes, but even after you replace them, if that lockwasher is still in place, it will give you trouble. Eventually, through vibration or whatever, it will loosen, fall off, and 50% of the time, bind your gearbox. As Rick said, take it off. It will not make a difference. But yes, disregarding my rant, the setscrew must be replaced.
EDIT--------------------
Not sure if the 2006 ones need it replaced though. Would have thought they'd have fixed that bay now...
-Sir Francis Bacon
-Albert Einstein
  #95   Spotlight this post!
Unread 19-01-2006, 21:56
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
So far we have a basic design. we are currently trying to get our robot to move around with out ruining anything. lol.
YAY! the magic smoke is back!! I haven't heard about any Victors smoking...you DO have it hooked up to the fuse block, right?
  #96   Spotlight this post!
Unread 20-01-2006, 00:39
jesusfreakmths's Avatar
jesusfreakmths jesusfreakmths is offline
AKA: Jonathan
FRC #1778
jesusfreakmths will become famous soon enough
Send a message via AIM to jesusfreakmths
I believe that we connected it right. The positive wire from the 120amp cut off switch connects to the 40amp fuse then straight to the victors, right?
well right now we have disconnected the fuses so that it doesn't run for now. we ordered two more victors and are still waiting for those to come in.
Jonathan
  #97   Spotlight this post!
Unread 20-01-2006, 10:59
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
right now we pretty much have alot done but we have alot to be welded right now so we really aren't ahead of the game as we planned
  #98   Spotlight this post!
Unread 20-01-2006, 11:45
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Please tell me you aren't drilling/cutting/filing metal above them? That will kill them really really nicely. Although the RC seems to withstand metal shavings in its pins, the speed controllers don't like them from what I hear.
  #99   Spotlight this post!
Unread 20-01-2006, 12:10
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Cad is 90% done
Chassis has been sent out for fabrication and welding
Drive trains are done
Ball capacity: 40
  #100   Spotlight this post!
Unread 20-01-2006, 13:01
Elgin Clock's Avatar
FRC #0237 (Black Magic)
We got pretty far.
Ball capacity: 149.
  #101   Spotlight this post!
Unread 20-01-2006, 13:07
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
We are pretty far behind, unfortunately. Our design team just started modeling our robot on Pro-E. We have the camera working smoothly, and we just finished our mock-up of our launching mechanism. It's amazing.
  #102   Spotlight this post!
Unread 20-01-2006, 13:58
Dark Paladin Dark Paladin is offline
Jedi Knight
FRC #1213
Dark Paladin is an unknown quantity at this point
Send a message via AIM to Dark Paladin
Talking Re: how far have you gotten on your robot?
We are shooting balls and moving around just fine time to practice our buts off!!
  #103   Spotlight this post!
Unread 20-01-2006, 14:29
AKA: Jonathan
FRC #1778
our board with all of the electronic parts hasn't even touched the robot yet! hopefully we will get it on the robot soon.
Jonathan
  #104   Spotlight this post!
Unread 20-01-2006, 15:22
occra 23.
AKA: ryo
None #1481
Originally Posted by Elgin Clock
We got pretty far.
Ball capacity: 149.
max that ball MAX capacity 149.
but still. are you serious? jeez.... so far we have. a nicely done aluminum frame done. and plenty of ideas.
  #105   Spotlight this post!
Unread 20-01-2006, 17:20
Note that this is not a real world maximum capacity. I would love to run cosmos (an add-on in SolidWorks) on the simulation and see where the balls lie in natural rest position. I could prolly get 150 at least in there. Maybe 160 *doube the amount available during one match*.
The way I put them in was to stack them nicely.
When is the last time you saw balls stacked nicely (re: neatly) in a FIRST robot that looked like a box???
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
