Go to Post I know what "finished" means, and I know what "robot" means, but what is this "finished robot" of which you speak? - Rick TYler [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-01-2006, 11:46
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
Re: Beware - transmission output shaft is not 5/8"!
We got our 5/8" sprockets to fit by filing them out with a rat tailed file, it took about 10 minutes per sprocket.
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
