Go to Post In all seriousness, here's a thought for everyone: Don't worry about what you can't control. - Rich Kressly [more]
Unread 12-01-2006, 13:01
red_alert_13 red_alert_13 is offline
AKA: Patrick Frampton
no team (Red Alert)
red_alert_13 is an unknown quantity at this point
Help: IFI loader not communicating with control unit
We are trying to hook up our robot controller to our computer to test the motors. We connected the two with a serial cable (the end connected to the robot controller went to the program port), and pressed the PROG button until the Program State light was a solid yellow. We ran the IFI loader program, and pointed it to the default .hex file supplied in the 2006 source code. When we clicked the download button it displayed a message stating: "Port failed to open". We tried with all 12 possible ports, none gave any other answer. We also tried using EasyC to download an unchanged project .hex file using the in-program download utility. This time, with port 2, it displayed the download progress bar, and at some point said that port 2 was open. However, after a few seconds, it stopped and told us to check to make sure that the serial cable was connected (which it was) and that the robot controller was on (which it was). We are out of ideas. Any suggestions would be helpful. This is our first year in competition, and we have NEVER used this software before. Thanks in advance!
Unread 12-01-2006, 13:26
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Help: IFI loader not communicating with control unit
Yeah, my team just acquired a new(er) laptop, and I was having similar problems, except that when the progress bar got partway across (there was no pattern to how far it got) it would just stop dead in its tracks. I fiddled with every setting possible in the device manager, and eventually came to the conclusion that the computer is a little f'd up. We got a usb-serial adapter and that works well enough. My suggestion: go to device manager and make sure your COM port is operating, and then just fiddle with every setting you can find. If that fails, try a new serial PCI card (if it's a desktop) or a usb-serial adapter (if it's a laptop).
EDIT: Oh yeah, and see if there's a BIOS update for your computer, sometimes the manufacturers figure these issues out and fix them for you.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 12-01-2006, 13:43
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
If I remember Indiana correctly, you're near Indy? The best way to solve a computer problem is to get someone to sit down infront of it. Ask a local team to stop by. If you have a mentoring team, that'd be ideal. If you need help finding one, check the mentoring thing on TIMS or contact IndianaFIRST.org.
Otherwise, I'd also suggest trying to get *any* serial device to work. If you can get a serial mouse or old PDA to work then you've eliminated a lot of potential problems and you can identify which port it is that you're plugging into.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 12-01-2006, 20:35
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Thing that caught me off gaurd when I first started playing with it, is the fact that you have to go to one of the menu's and click verify controller or some other such thing, and it checks if the controller is at the other end before one can upload anything to it. Might want to check that as well.
My Blog!
Unread 12-01-2006, 22:18
Back after 4 years off
FRC #5279
red alert, it sounds like you could have a bad serial port, try it on another computer, IFIloader tends to be very tempermental. If that doesnt work then uninstall and reinstall every thing(the solve all windows fix). If you are still having problems then see if you can borrow another teams rc to make sure that isnt the problem(it probably wont be).
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 13-01-2006, 11:13
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
My team had a similar problem. And turns out we can only upload through one serial cable. We had 2 connected and it wouldn't communicate, but both worked fine individually.
Unread 14-01-2006, 21:16
binary_sandman's Avatar
binary_sandman binary_sandman is offline
AKA: andrew sweet
FRC #1388 (Eagle robotics)
binary_sandman is infamous around these parts
well {red_alert_13} our programing team has had hardly any proplems with already finishing drive moters and Autonomous mode.
by the way program state is organge
your on board electronics system could not be Operable .
team 1388
2004 curie divison winners
Unread 14-01-2006, 21:40
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
team 1388
OK, this is the SECOND post you made touting your "already finishing drive moters and Autonomous mode" and lacking any help towards moving the thread in a positive direction.
Please, elaborate. What does it do? Drive forward? Collect balls? Score all ten balls in the goal? Keep arrogant, belittling and misspelled bragging off these boards.
I am going to second what JamesBrown said. It may be as simple as a broken serial port. Try it on another computer. If it does not work on another computer, I would call up IFI and ask for a replacement.
http://www.mikesorrenti.com/
Unread 15-01-2006, 00:36
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Bragging is never smart...
Make sure you don't have something silly happening like somethings bound to the port in question.
http://www.sysinternals.com/Utilities/Portmon.html is a good utility for checking that.
Matt Krass
Unread 20-01-2006, 17:30
thecheatdx thecheatdx is offline
AKA: Cameron Christensen
FRC #1388 (Eagle Robotics)
thecheatdx is on a distinguished road
Originally Posted by Mike
*post*
I would like to personally apologize to CD for the actions of the aforementioned member of my team. I'm the Programming team leader and the member is part of the programming team so I'll sit down with him and make sure these sort of posts don't continue to pop up.
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
IFI Loader Reloaded sciguy125 Programming 26 07-08-2007 00:07
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
IFI Loader Doc's Raven_Writer Programming 0 21-01-2004 17:53
Bug in IFI Loader rwaliany Programming 2 06-01-2004 21:26
