Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 20-01-2006, 18:24
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: problems using gyro/adc code with camera default code
Originally Posted by tanstaafl
I started with the camera "bells and whistles" version.
now, because this header file is enclosed between < >, that means it's the compiler's problem to include it, right? or do I have to actually add it to the project file list? I've tried both, just adding the #include part to user_routines_fast.c, trying with both the < > and " " signs, and I also tried actually adding the p18f8722.h while using < > and " ". none of it worked. are there other source files I need to add the #include <p18f8722.h> line to besides user_routines_fast.c? or is that even the source file you were talking about in the first place?
Okay, it sounds like MPLAB doesn't know where the header files are. Mark McLeod, one of the resident experts on compiler weirdness, posted this: http://www.chiefdelphi.com/forums/sh...53&postcount=6. Hopefully that'll fix your problem.
-Kevin
Kevin Watson
http://kevin.org
interrupt in default code Gal Longin Programming 5 04-02-2006 20:10
If you could write the default code... Kevin Watson Programming 18 04-08-2005 10:41
Combined Camera and PID/Encoder Code Terry Sherman Programming 1 14-03-2005 17:59
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
