Go to Post There's more elegant ways to play defense than beating on the other robot. - Bill Moore [more]
Unread 20-01-2006, 19:27
Rachika Garcia's Avatar
Rachika Garcia Rachika Garcia is offline
AKA: Brian Armstrong
FRC #0399 (Eagle Robotics)
Rachika Garcia is on a distinguished road
Send a message via MSN to Rachika Garcia
Tires
From what point do you measure the diameter of a tire. Is it from the outer edge of the tread or is it from the plastic part of a pneumatic tire?
Unread 20-01-2006, 19:31
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Tires
The "plastic edge" is known as a hub and the wheel diameter includes the tire.
If buying online or without the ability to measure, check with vendor for sprcific measurments before buying, if it is of a critical nature.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 20-01-2006, 19:32
Re: Tires
I believe it's from the outer edge of the unmodified tire. So an 8" Skyway would have tread with its outer edge at 8", and be classified as such even if you grind all the tread off.
Tires wmurphy Technical Discussion 11 25-01-2005 08:35
Where to get solid tires? sanddrag Technical Discussion 2 28-02-2004 13:08
durability of the pneumatics tires oreocookeee Kit & Additional Hardware 2 19-01-2004 02:17
Wheel wear??? 6" Pneumatic tires??? Scott358 Technical Discussion 11 29-03-2003 13:35
How good are your tires?? com General Forum 44 29-01-2003 15:38
