Go to Post The world is run by those who show up. - AdamHeard [more]
Unread 20-01-2006, 18:54
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Crate Information
The crate rules say
"The crate must 'sit' on two 4" x 4" lumber, ..."
Does this mean 4x4's (which are really 3.5x3.5) or like 4x4's with half inch plywood on it to make the bottom actually sit 4" off the ground.
Thanks.
Collin Fultz
Unread 20-01-2006, 19:34
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Crate Information
I think the most important thing is that it can be moved by a forklift. Our crate sits on a plastic pallet (to save weight) and there are no issues.
Ricky Quinones
Director of Sales - VEX Robotics
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
The dimensional lumber is fine. Pallets and skids in commercial use use regular dimensional lumber. For the same reason, to allow a forklift to lift them.
Unread 04-02-2008, 08:47
aepstein's Avatar
aepstein aepstein is offline
FRC #2423 (KwarQs)
aepstein is an unknown quantity at this point
So, we're constructing our crate using a commercial wooden shipping pallet as the base. Although not exactly in the rules ("...crate must sit on two 4" x 4" lumber spaced 28" apart..."), will this pass FedEx muster?
Unread 04-02-2008, 10:56
jhaugen jhaugen is offline
J. Haugen
FRC #0842 (Carl Hayden Falcons)
jhaugen is an unknown quantity at this point
Lumber doesn't come in "real 4X4" demension any longer. Commercially bought 4X4's are what is used. Fork lifts can get under them and move them as needed. Good luck. By the way, Ricky Q., is your plastic pallet commercially built? or custom built?
Unread 04-02-2008, 11:20
yee haw!
Commercially built by Orbis Corporation, they manufacture plastic everything for a lot of different industries. And they happen to be based in our hometown.
www.orbiscorporation.com
2 years later our crate has not missed a beat.
Ricky Quinones
Unread 04-02-2008, 12:50
GaryVoshol's Avatar
Cogito ergo arbitro
There are different kinds of shipping pallets.
Some have 4x4 (or greater) skids with appropriate 28+ inch spacing between them.
Others do not - most commonly you see pallets that are made of thinner slats, top and bottom, with 3 or more rails running front to back.
While a fork truck can get into the spaces between the rails, other types of lifts cannot. At the competition venues I have been, they use hand carts to move the crates around. These carts have a long tongue that goes into the open edge of the pallet between the skids, and then is lifted hydraulically. These carts cannot handle the center rail in a slat construction pallet.
(since 2004)
Unread 04-02-2008, 16:08
bluefluke bluefluke is offline
bluefluke is an unknown quantity at this point
I remember hearing something about new rules regarding the top and bottom faces of the crate. The rules said that the top and bottom of the crate MUST be constructed of 3/4'' plywood. I do not know if this is a rumor, or true. If anybody can tell me if they heard the same rule, I'd really appreciate that.
Unread 04-02-2008, 16:32
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Many many many examples are in the gallery here:
http://www.chiefdelphi.com/media/photos/tags/crate
Unread 04-02-2008, 17:30
False. Q&A allows a metal crate, which would include top and bottom--but you still need the 4x4s underneath. See Section 4.
**FIRST EMAIL**/Important December 2nd Deadline Information Pat Fairbank FIRST E-Mail Blast Archive 0 21-11-2005 17:34
Information Technology or Information Systems ? pheNIX637 Career 1 27-10-2005 18:43
**FIRST EMAIL**/Important December 3rd Deadline Information - Please Read! dez250 FIRST E-Mail Blast Archive 1 23-11-2004 13:35
Your Shipping Crate JohnBoucher Technical Discussion 21 26-07-2004 15:08
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 09-04-2004 21:12
