Go to Post I didn't know that Dean Kamen had 3 arms. - kevin.li.rit [more]
Unread 20-01-2006, 17:12
felipe.reis's Avatar
felipe.reis felipe.reis is offline
felipe.reis will become famous soon enoughfelipe.reis will become famous soon enough
Perfect Calibration Image....
Hi, we´re having some trouble to calibrate the cmu cam, the green light appears white on the image, even when we uploaded the cfg file for the target light, can anyone post a image with a perfect calibration and the settings?!
thnx,
Felipe Reis
Unread 20-01-2006, 17:55
ChaChee's Avatar
ChaChee ChaChee is offline
AKA: ChaChee³
None #1372 (Lambda Cubed)
Team Role: Mascot
ChaChee is an unknown quantity at this point
Send a message via AIM to ChaChee Send a message via MSN to ChaChee
Re: Perfect Calibration Image....
Our camera is having the same problems also. Any input as to how to fix it would be appreciated
Unread 20-01-2006, 18:10
Kevin Watson's Avatar
La Cañada High School
FRC #2429
If you're using the FIRST green light, you don't need to calibrate the camera for most lighting conditions. Just load camera.hex and the camera should find it using the default calibration values.
-Kevin
Kevin Watson
http://kevin.org
Unread 20-01-2006, 20:03
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Also, if you would like to have the CMUCam GUI see the target properly, see my post at http://www.chiefdelphi.com/forums/sh...d.php?p=433127
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 20-01-2006, 21:07
I was calibrating using Labview, but if theres no need to calibrate with Labview... for what that LabView´s program is used for? Do I really have to use it for something?
thnx,
Felipe Reis
Tribotec Team #1382 - Animator
Tribotec Forum - Brazilian Teams!
Unread 20-01-2006, 21:59
Eldarion's Avatar
thnx,
Felipe Reis
I have just been using the CMUCam GUI from last year--it works great!
If you know how to use LabView and want to use it instead, you could always try sending a "CR 3 2" to the camera first. This will lower the saturation value to 2, which will fix the light problem. Keep in mind that this will only work if LabView doesn't reset the camera first.
By the way, the camera communicates at 115200 baud, just use HyperTerminal.
-- Thomas Paine
-- Anonymous
Unread 21-01-2006, 03:25
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
The LabVIEW CMUCam2 application does reset the camera. It also has an entry to change all of the settings for the camera, including the saturation, without the need for a terminal application.
You can also load values for all the settings from a file. 2 configuration files are packaged with the application. One is the default for this years target (a suggested base line if tweaking calibration) and the default camera settings (for typical imaging).
If you are having trouble getting your camera to track, the LabVIEW application is a way to verify that the camera is working, that the settings are tracking properly, and to prototype other code that responds to the camera's feedback.
Cheers!
-Joe
Unread 21-01-2006, 13:00
Well, theres a little bug in the LabView program, sometimes, only sometimes when I press the grab button , the download progress bar starts to advance, but it gets stuck in the end, the image doesnt appear and we have to restart the programm....
Any idea why is it happening?
thnx
Unread 21-01-2006, 17:25
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
thnx
You need to get the updated labview application from the ftp site (ftp://ftp.ni.com/outgoing/FRC/), the version updated on 1/17/06 fixes this issue. WE had the same problem as you, until Joe H. suggested getting the new version.
-Eric
Unread 25-01-2006, 07:18
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
We are having the same problem. It seems that the camera sees any type of light (different colours) as white light and always tracks the fluorescent lighting instead of the light source.
Do the values we load to the camera in LabVIEW affect the camera when it's running off of Kevin's code?
It should track the green light fine and not mistake it for and fluorescents even though in LabVIEW it does?
Thanks in advace
www.sabrerobotics.com
Unread 04-02-2006, 14:06
Estrual Estrual is offline
AKA: Ryan Tanner
FRC #1782 (BlueJay Robotics)
Estrual is an unknown quantity at this point
-Eric
That sounds pretty useful, but is there another place to get it? Our school server is denying me access to the FTP. So, if there is another way to get it, please reply. Thanks! ~Estrual
Unread 04-02-2006, 18:36
Denz's Avatar
Any conditions in Kevin's code that I can change so that it doesn't see the fluorescents at all?
Unread 04-02-2006, 18:49
So far as I can tell, the camera code from Kevin Watson already ignores fluorescent lights rather effectively. The only thing I've seen trick it has been daylight through the windows of our shop.
Estrual, if you can't convince your school's network administrator to let you get through to the NI ftp server, you'll probably need to have someone download the LabView files at home or work and bring them to your team's programming computer on a flash drive.
Unread 05-02-2006, 00:25
Denz's Avatar
It ignors them most of the time, but sometimes if finds one.. atleast in our electrical shop it does. Any settings I can change so it doesn't see them?
Unread 05-02-2006, 00:47
Tureyhall Tureyhall is offline
AKA: Thomas Hall
FRC #0668 (Apes Of Wrath)
Tureyhall will become famous soon enoughTureyhall will become famous soon enough
-Eric
ok, i've serched the ftp and can't find what your talking about..... help?
/*Nerd Camouflage*/
2005 SVR - 668+1072+840 - Semifinalists.
2006 SVR - 668+1280+1693 - Finalists.
2007 SVR - 668+604+624 - Quarter-finalists, Xerox Creativity Award, two highest scores (290-2, 128-0) at SVR.
2007 Nat's - TBA.
Strange CMUCam Image Sidney San Martín Programming 22 27-01-2005 15:00
New cool image generator Elgin Clock Computer Graphics 13 03-11-2004 20:10
Getting an image from a website Raven_Writer Website Design/Showcase 17 09-06-2004 11:39
extra image discussion text rbayer CD Forum Support 15 06-05-2004 19:04
