Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 20-01-2006, 20:25
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
IR Beam Troubles
Has anyone got the IR Photoswitch beams working? We tried wiring them up but got a .01V signal.
We do have it running on 12v power.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 21-01-2006, 12:21
AMIRAM AMIRAM is offline
AMIRAM is an unknown quantity at this point
Re: IR Beam Troubles
did u connect a pullup resistor ???
the output is o.c u know...
Unread 21-01-2006, 17:15
Translation:
Did you connect a pull up resistor? The output is "open collector".
"Open collector" means that it is essentially a contact closure to ground, not a logic-level voltage. It should work fine when connected to a digital input on the RC, because a contact closure to ground is exactly what the RC expects (it does provide pullups on its inputs).
Tilt Troubles Mumford 406 Programming 4 29-03-2005 22:19
Gyro Troubles SteveO Programming 13 30-01-2005 16:46
International Team Troubles Jacqui Sutton General Forum 26 24-03-2004 07:37
Maxi Block Troubles MARobotics Electrical 3 27-01-2003 07:39
Robot Controller & Operator Interface troubles patrickrd Technical Discussion 10 25-10-2001 07:36
