Go to Post For example, you can make a car as safe as possible. It may get the highest safety ratings in it's class, but if you drive it off of a cliff there really isn't much you can do about that. - jmanela [more]
View Poll Results: Where does the ball exit your robot?
Front/back 53 51.46%
Side 13 12.62%
Upper 62 60.19%
Lower 23 22.33%
Multiple Choice Poll. Voters: 103. You may not vote on this poll
Unread 20-01-2006, 21:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There are many design challenges in deciding where the ball should exit the robot (for 3pt goal scoring purposes). Where do you have it exiting? If you selected high, can you please explain the route the ball takes (all the mechanisms it goes through) to get to the exit point? Thanks.
Unread 20-01-2006, 22:20
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
Re: Where does the ball exit your robot?
The ball is released from the storage and launched towards the back of our robot by three wheels of increasing speed. Then it runs on a track which directs it from the bottom of the robot and launches it from the top of the robot shooting forward.
pretty nice setup though. low center of gravity and we can change the angle of the launcher.
Unread 20-01-2006, 22:32
Best Available Data
FRC #1778 (Chill Out!)
Okay I'm scared, really scared. Since when do teams know what their main scoring mechanism is going to be in week 2!
Unread 20-01-2006, 22:35
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
How can you not know by now? You need to start ordering parts and such, or you won't have any time to build...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 20-01-2006, 22:37
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Ours goes out the top... in any direction. I'm not 100% on the design of it though. It's changed about 50 times since we originally voted on the design.
Unread 20-01-2006, 22:48
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We've decided the ball should launch out of the side of our robot, and could possibly be on a turret of some sort (this turret will not allow 360 degree rotation though).
The current plan is to also have it leave the robot high up. The ball will be picked off the ground by a conveyor belt and roll through a slightly angled trough (similar to the chutes that move gumballs in gumball machines) to our shooter, where there will be some sort of stopper to prevent balls from automatically rolling into the shooter and firing. The prevailing idea for the actual shooter is to then have the balls roll underneath a rotating wheel, and be carried around the wheel so that they fire out above the wheel in the opposite direction. So the two lifting mechanisms will be the conveyor belt and the shooter itself.
The actual shooter has changed in design every few days though, so the shooter might change again, but the rest should stay the same.
Unread 21-01-2006, 18:15
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Blasted. No option to pick multiple places in the survey?
What's up with that?
Unread 22-01-2006, 00:34
occra 23.
AKA: ryo
None #1481
who said anythign about a MAIN scoring method?
Unread 22-01-2006, 09:34
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I agree. We'll be dumping from the back and shooting from the side. Assuming we get it all to work and work together. This is a common problem I'm having with polls - our robot usually incorporates a mix of possible answers. Maybe we should name this year's bot "melting pot".
Hi!
Unread 24-01-2006, 19:31
mallot1243's Avatar
mallot1243 mallot1243 is offline
FRC #1243
mallot1243 is an unknown quantity at this point
We're planning on a ball hopper connected to a turret with ~180 deg turning ability, we already built up a mock up and now we need to tone down the robot because it already shoots balls too fast
by week 2 you should already have some design done to eliminate week 5 headaches (2k4... grrrr...)
Unread 24-01-2006, 21:27
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
If you shoot from the top your half way there.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 24-01-2006, 22:05
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Yeah, I would very much like to be done with designing our main scoring method, but we're still testing a bunch of methods. I pretty much have no idea what our robot is even vaguely going to look like. (except the chassis (and the controls))
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 24-01-2006, 23:49
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
The ball will be exiting the robot above 5 feet (or very close to there) and towards the front. This is accomplished by a mid-height baseball shooter at the back of the robot shooting forward and angled up significantly.
Oh, maybe I shouldn't have pushed that...
Unread 25-01-2006, 01:35
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Ball goes up, round round round round round round round round and then appears at the bottom of the robot. And then gets shot out the side. Hu???
Any ideas on what 1072's robot will look like? A hint: a lot of fiberglass was used.
Unread 25-01-2006, 09:42
Taylor's Avatar
AKA: @taylorstem
I'm envisioning a nautilus design, maybe in keeping with the theme of the FLL challenge?
Hi!
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Honda's robot... Don Wright Math and Science 7 17-12-2005 13:15
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
Beatty's 2004 Robot mzitz2k General Forum 81 26-03-2004 15:18
