Go to Post The robot was spinning, I dont have the energy to spin like that. - Joe Menassa [more]
Unread 20-01-2006, 21:46
Nine9cracker's Avatar
Nine9cracker Nine9cracker is offline
Newbie in training
AKA: Felix hong
FRC #0368 (kika mana)
Nine9cracker is an unknown quantity at this point
Data stream
Does anyone know how they are going to steam the data for amount of teeths from gear-tooth sensor or pan angle to the comp w/o attaching the programming cord to the bot itself? If so plz direct me.
Leela: They say Zapp Brannigan single-handedly saved the Octillion system from a horde of rampaging Killbots!
Fry: Wow.
Bender: A grim day for robotkind. Eh, but we can always build more Killbots.
Zapp: "Killbots? A trifle. It was simply a matter of outsmarting them."
Fry: "Wow, I never would've thought of that."
Zapp: "You see, killbots have a preset kill limit. Knowing their weakness, I sent wave after wave of my own men at them until they reached their limit and shut down."
Unread 20-01-2006, 22:19
Electrical Engineer
Rookie Year: 1995
Re: Data stream
Felix,
I have no idea what you are asking...
Mike
Mike Betts
As easy as 355/113...
Unread 20-01-2006, 22:27
Newbie in training
AKA: Felix hong
Re: Data stream
OK I know rushing was bad but this is the best I can try to explain it. Is there a way to view the data from the robot(pan angle , gear tooth sensor reading) w/o hooking the programming cord to the comp. I know we can't have a cord connect to the robot during the match
Unread 20-01-2006, 22:47
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
Re: Data stream
the dashboard port on your operator interface allows you to get feedback from your robot during a match
the white pages have some very good programs for sorting out that data from your serial port and putting it in a format you can use as useful feedback
these might help:
http://www.chiefdelphi.com/forums/sh...dashboard+view
http://www.chiefdelphi.com/forums/sh...hboard+program
http://www.chiefdelphi.com/forums/sh...ad.php?t=41214
and if you do some digging in the white pages there is a lot more to stir up the idea train
work that VB!
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 20-01-2006, 23:21
Electrical Engineer
Rookie Year: 1995
Re: Data stream
Felix,
First of all, thanks for the translation...
The method Rufus has illuminated is, unfortunately, the only numerical method of getting info to the drivers that I know of. However...
If you were to mount a servo on the robot with an indicator pointer large enough to be seen by the drivers...
Actually, my team has used this method for digital information (ie: the claw is locked onto the bar, et cetera) when the drivers were unable to take their eyes off of the "action".
If however you do not need the data in real time, search for the term "EEPROM" in these fori archives...
Good luck,
Mike
Mike Betts
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
dashboard data stream archiver 2000 10 23-06-2002 22:56
