Go to Post More teams will want to join, peers who are not on the team will understand the program better, television will become interested in FIRST again, sponsors will be easier to get, cancer will be cured, the Israelis and Palestineians will live in harmony, and we will have world peace. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 20-01-2006, 02:36
David Sherman David Sherman is offline
FIRST College Student Mentor
FRC #0973 (GRR)
David Sherman is on a distinguished road
Send a message via AIM to David Sherman
KOP Gearboxes and noises
I was curious if the gearboxes this year still rattle from the metal washer inside or if FIRST has tweaked it? Otherwise my drive team will need to get nylon washers and take apart the gearboxes haha, I think the point is made.
Unread 20-01-2006, 10:35
Re: KOP Gearboxes and noises
So far, our new KOPboxes are like butter.
Unread 20-01-2006, 23:33
FRC #0973 (GRR)
Thanks, thats a relief. I'll keep my fingers crossed for ours to run smoothly also.
FRC 973
2008-Present:College Student Mentor
FRC 599 2003-2007
Unread 21-01-2006, 00:52
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Our gearbox makes some rattling noise, but very minimal and when it is understress it is pretty quite. Funny thing is that we always are missing 1 to 4 plastic spacers. But it's ok.. Osh is up the street. For all I know it should move smoothly, try grease if you need it, It can really help.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 23-01-2006, 00:19
Evil Robotics's Avatar
Evil Robotics Evil Robotics is offline
Git er done!
AKA: Barry Anderson
FRC #1245 (Shazbots)
Evil Robotics is an unknown quantity at this point
Team 1245 has noticed that if you squeeze the two motor toward each other a bad noise will go away. This was noticed on more than one gearbox. Ous solution was to use a large worm drive hose band clamp.
Has anyone noticed the same thing? Yes we did see the note on the set screw height.
Barry Anderson
www.evilrobotics.net
Unread 23-01-2006, 07:47
Gdeaver Gdeaver is offline
FRC #1640
Did you check the Spring clip on the cim gear. Our clip was touching the opposing gear. A little grinding with a Dremel tool and sanding drum removed enough of the clip to give some clearance.
Unread 23-01-2006, 18:12
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
we just finished putting our gear boxes back together and yes they do rattle. i heard from some post that if you grease all the gears and run them for 20-30 minutes at a time that eventually the noise becomes less and less. we are doing this and it is helping. hope this helps.
In life, if what we want and what we get isnt what we expected, then thats life, because we cant always get what we want and what we get is never what we expected.
This is our teams offical website, enjoy:http://www.angelfire.com/droid/roswellrobotics/
Unread 29-01-2006, 13:33
Dick Linn's Avatar
no team (Synergy)
LAst year, we had to pinch the two motors together with a hose clamp to eliminate noise. Maybe we didn't assemble something right, but that did the trick. The motors weren't in perfect alignment without them.
We'll know about this year's setup on Monday, but they don't look as bad. We did follow the instructions carefully and everything fits up better this year.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 29-01-2006, 13:37
Andrew Blair's Avatar
FRC #0306 (CRT)
This is actually recommended by IFI, though they never suggested that you would need to use a hose clamp. By moving the gears together, you're changing (lessening?) the amount of backlash between drive gears in the box, which evidently needs to be adjusted in each individual gearbox.
-Sir Francis Bacon
-Albert Einstein
