Go to Post The real key to drive team coaching is to tie your jacket around your waist. Got a couple championship rings that way. - TravusCubington [more]
Unread 20-01-2006, 06:31
Makubesu's Avatar
Makubesu Makubesu is offline
None #1768
Makubesu is an unknown quantity at this point
Send a message via AIM to Makubesu
Ways to speed up code loading process?
Whenever we load our code onto the robot, it takes forever. I understand that this hardware has its limitations, but just to make sure, is there anything I can do when making the hex file in MPLAB to make it load up faster?
Unread 20-01-2006, 06:44
Re: Ways to speed up code loading process?
To maximize download speed, use a fast computer with a built-in serial port. Most USB-to-serial converters slow down the process a lot.
Unread 20-01-2006, 22:22
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
I was having the same problem, it is taking 17 minutes and is barely above 50%. But if we are not able to get a a laptop with a built in serial , are any other conection converters usefull? The laptop has only a few things but the only other thing that might be usefull is some type of connection that I don't know its name so I'll make it on here somewhat well it looks like a serial port (female) with 3 rows of 5 holes kinda like this if you can under stand it. Ok I'm an idiot so I couldn't find it but This should be enough to figure out what I mean.
its a little more compact....
Thanks
Unread 20-01-2006, 22:35
Jared Russell's Avatar
Taking a year (mostly) off
That's a VGA monitor port
You can try to get a PCMCIA serial port card - but they can be pricey.
I really don't understand why USB adapters slow things down so much - it's not like USB is the bottleneck in the system.
Unread 20-01-2006, 22:37
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
The factor which regulates the speed of download is how much the USB adapter is capable of buffering. Make sure your adapter is using the largest possible buffer...
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 20-01-2006, 23:34
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Ok, But....How?
I still don't allways know to much about this stuff so, I just want to make sure I have everything correct before I mess with something I don't want/need to.
Also it took 33 min to upload the code to the controller
Thanks a lot.
And as for the adaptor that cost a lot how much do they on average cost? do you mean costly for an adaptor or just plan expensive.
Unread 20-01-2006, 23:46
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Originally Posted by Oumonkey
Ok, But....How?
Holy. Crap. Do you know any of the specs on the machine you're using? Pentium 3 or so? There's usually a little sticker on it somewheres...but that's beside the point.
To make sure you have the biggest buffer possible (I'm assuming you're using Windows 2000; not sure if these directions work in XP):
1. Open the Control Panel -- usually Start > Settings > Control Panel
2. Double-click System.
3. Click the Hardware tab.
4. Click the Device Manager button.
5. Expand the "Ports (COM & LPT)" item. Under it should be a port or two. Pick the one you plan to use with the robot controller (usually the highest number after "COM") and double-click it to open the properties window. Under one of the tabs (in my case it's Advanced) there will be an Advanced Port Settings button. Click it, and there should be a window with "FIFO" buffer settings. Make sure the sliders are moved all the way to the right, as this will make sure the buffer is as big as it can be.
That should do it. If it doesn't speed up, try using another serial cable, another USB-to-serial, or even another computer. I would like to say it's a driver issue, but it is HARD to find the right driver if you don't know exactly what you're doing...and its harder to walk someone through it.
Good luck on this,
JBotAlan
PS. If you found this helpful, good rep is always nice
Aren't signatures a bit outdated?
Unread 21-01-2006, 06:34
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Cool, Thanks. I'll try this as soon as I get the laptop running.
And I'll give some rep to you guys, I just learned how to do it yeasterday...I thought it was some kind of post count for a while
Edit: Oh and I'll get the specs down soon, I thoiught it was a decent laptop at first. 256 ram I know, but thats all I can remember.
Unread 21-01-2006, 09:38
Makubesu's Avatar
None #1768
Woah, we switched over to the pure serial connection using one of the school's laptops, and it takes like 30 seconds to complete! That's awesome, it was taking hours before Thanks for your help everyone.
Unread 21-01-2006, 14:09
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Ya, I know I am going to try and get the other laptop if I can but it may be hard, out IT is a jerk somtimes.
But It is a lot faster, I wasn't able to play with the usb converter but I'll do it tonight.
Unread 21-01-2006, 17:23
phrontist's Avatar
Proto-Engineer
Wow... hours! I can't imagine that. I'm used to it going down in like... 5 seconds. With USB it's more like 25 sometimes...
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
Program for variable speed cabbagekid2 Programming 5 12-01-2005 13:20
Need PBASIC Balance Code Quick sanddrag Programming 1 11-05-2004 13:02
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Speed limiting code from last year in C? Josh Siegel Programming 6 01-04-2004 22:27
