Go to Post Easy, we use Magic. Your team wasn't given that in the kit? - Michael Hill [more]
Unread 20-01-2006, 11:45
TheAnsweris42's Avatar
TheAnsweris42 TheAnsweris42 is offline
Team 1896 "Rules Guru"
AKA: Kenneth Casperson
FRC #1896 (Xodus)
Team Role: Webmaster
TheAnsweris42 will become famous soon enoughTheAnsweris42 will become famous soon enough
Send a message via ICQ to TheAnsweris42 Send a message via AIM to TheAnsweris42 Send a message via MSN to TheAnsweris42 Send a message via Yahoo to TheAnsweris42
Motors/Battery life
Some members of the drivetrain team went down to a company that makes motorized wheelchairs a while back, and came back saying that we can't run four CIMs on the battery, alone without electronics, and still have enough battery life. I contend that last year, several teams ran more than four motirs, plus electronics, the compressor, etc, and still ran it. And since the battery is pretty much the same 12v-18a power supply ((Can anyone clarify the difference between the ES-18-12 and this years EX-18-12?)), we should be able to run ours. DOes anyone have any adivce on this? I think we should at least run two motors for each transmission on a RWD system, but they keep saying it wont go...
Also, what motors do you recommend for the drive system? On a RWD I mean.
"A common mistake people make when attempting to engineer something completely foolproof is to underestimate the ingenuity of complete fools"
-Douglas Nathaniel Adams
Unread 20-01-2006, 11:48
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Motors/Battery life
In terms of the company that makes wheelchairs, no it wouldn't have enough battery life. We ran 4 CIM's, 1FP, pneumatics and electronics last year. Worked fine, and we had a battery life of maybe 10 minutes (while driving the robot around constantly, but not stalling the motors)
It's definitely possible.
Unread 20-01-2006, 11:55
In 2005 we used 4 CIMs for the drivetrain, used three pneumatic cylinders (one large and two small), and another big motor for our arm joint. A battery charge would last for two matches easily. Given the maximum current draw through the fuse/breaker block, I don't think you could run out of battery power in two minutes.
Unread 20-01-2006, 12:04
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Our 2005 robot had a compressor running a lot, 4 cims on the drive train, and 2 FPs on the tetra elevator. The drive train was geared for torque and the elevator was geared for speed, so we drew a lot of current. Our effective battery life was about 4 minutes, but who cares with a round that is 2 minutes long.
Using the two new cims along with all the other motors WILL murder your battery. So my humble opinion is, try not to use 11 motors. My team is using 7 this year, along with the compressor, and WE'RE worried about power issues.
Don't build a battery killer. Please, think of the batteries.
Unread 20-01-2006, 12:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Sometimes you really have to question what professionals tell you if it just doesn't seem right. The battery life probably would not be sufficient for a wheelchair but most definitely would be for an average FIRST robot. Also, the battery is rated as 18 Amp-Hours capacity, not 18 amps supply. Roughly roughly speaking, it means you can continuously pull one amp for 18 hours or 18 amps for one hour, etc. You should look at the spec sheet http://www2.usfirst.org/2005comp/Specs/batex.pdf for a more specific answer.
Plus, twice the motors doesn't automatically mean twice the current draw. What it does automatically mean, is almost half the loading each, which would mean approximately half the current draw (maybe a little more) each resulting in the total current draw of the drive system being only slightly higher than with only two motors. It is kind of the same concept as walking in snow with stilts or walking in snow with snowshoes. You weigh the same no matter what, but the snowshoes distribute the load better, because they have more area. For a robot, more motors, more load distribution. Less current draw per motor. Only slightly more current draw total.
Unread 20-01-2006, 12:36
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
From the 2005 Q&A
Q: Can we use previous years' batteries? Having only 2 batteries (which last only 1 or 2 rounds) will not last the entire day on Friday. The batteries take hours to fully charge-2 aremn
A:You may use batteries from prior years as long as they are the same make and model as the competition batteries. Note: EX18-12 and ES18-12 batteries are equivalent batteries.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 20-01-2006, 14:55
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
We ran 4 CIMs, 1 motor for the turret, and 1 motor for the pulley to raise our lift, and all the accompaning electronics without and issue. battery life was pretty long in terms of robots (15 minutes or so).
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 20-01-2006, 15:38
Ken,
The answer to your questions...
The kit batteries are more than enough to run a robot in our competition for a two minute match. Efficient drive systems, those with a well designed transmission and reduction (translates to about 8-12 ft/sec no matter the number of motors used) and low losses in steering/turning and the ability to push without stalling the motors should be fine. Things that eat batteries are robots designed for high speeds, robots that encounter extreme currents in turns, robots that stall multiple motors regularly and robots that run almost continuous on the air compressor.
There is no difference in the ES or EX battery. They are the same amp hour and output voltage rating. However, there are some manufacturer/suppliers that will tell you their battery is a equivalent, cross reference or a replacement. Do not accept substitutes, the only allowed batteries are the ES or EX battery.
You should have no problem running a four motor, kit transmission, (all Chalupa/CIM) RWD robot provided you do not try to couple large diameter wheels or design a step up gear ratio between the wheels and the transmission. Provided you do not expend a lot of energy on the rest of the robot systems.
Unread 20-01-2006, 16:34
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Its much more closer to 1 amp for 18 hours. If you look at the specsheet you linked, the 18AH of capacity is rated for a 20 hour discharge. According to the specsheet, for an 18A discharge, you only get about half that capacity.
Interestingly enough, I've been running some tests on a fixed 1.2 ohm resistor (so approximitally a 10A discharge rate, average), and getting about 85-90 mins of run-time before the circuit automatically shuts off and re-charges at 10V. The spec-sheet only shows about the same time (maybe even a little less), so I'd say those numbers are pretty good (or atleast the 10A discharge rate #). I haven't bothered with lower discharge rates, and I need some bettter cooling for my resistor before I can go to greater discharge rates.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 20-01-2006, 17:41
Some members of the drivetrain team went down to a company that makes motorized wheelchairs a while back, and came back saying that we can't run four CIMs on the battery, alone without electronics, and still have enough battery life. ...I think we should at least run two motors for each transmission on a RWD system, but they keep saying it wont go...
In this case, I would have to say that the wheelchair people don't know how little current a FIRST robot can draw. An example: 330's 2005 robot has 8 motors (4 CIMs, 2 FPs, and 2 window motors). We ran it for 45 minutes on two batteries, and the only reason we stopped was because it was getting hot under the lexan sides. Need I say more?
For the drive, the CIMs are probably your best bet. Four small ones will do the trick, with power to spare. If you can do four, do four. If a motor in the drivetrain fries suddenly, you want a backup (even though it's hard to fry a CIM).
Unread 20-01-2006, 18:29
FRC #1896 (Xodus)
Feels good to be so thouroughly vindicated - thanks a lot, you really helped, all of you. I'll bring it up again at tomorrow's meeting, we'll have to start trying these things ourselves...
Unread 20-01-2006, 21:00
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Sanddrag et All,
I've performed continuous 50A load discharge FIRST KOP 18AH SLA Battery tests to 'exhaustion'
The discharge Vbatt Vs time characteristic for this years is different in shape with less time at a lower Vbatt for 2006 Exides - perhaps slight different electrolyte implementation ? (requiring P/N change?) Ca Vs Pb?
(2003-5 Ca were 13.30v fully charged Vfloat Vs 13.00 to ~31.10 for 2006
else lot deviation on batts we got though BOTH of this years show this.
Specifically, with a 100% Midtronics charge
(achievable only by overnight charging i.e.
[fast charge to ~80% capacity+several hours capoff for remaining 20%]
(100% not likely achieved during multi-chg-dischg during competition =~80%)
Tests results:
9 min life with Vbatt@term 13.10v noload, @50A load quickly down
11.61v then gradually ending at 9.72v at 9 min,
Vbatt@term drops roughly linear, ~2mV/sec
note: Rload is ~constant so current gradually decreased with time, I=V/R
R=11.61v/50A = .22ohm (note: add .5A @11.61v from fan load)
Equipment:
DMM direct to batt terminals,
Two each Harbor Freight 12v 100A Battery/Load testers in Series (~$15ea)
(50A load for longer test time and match typical 2005/6 robot drain)
Used large 12V .5A KOP fan over vent holes to extend test time over
mfr 10 sec limit
(keeps resistor element loads from burning bright red over 9 min test)
Vbatt@terminals taken ea 10 sec & imported to excel spread sheet & graphed
I don't have the data & graphs on this computer but will post, if requested.
BTW this method/data was presented at my FIRST Advanced Electronics 2005 Workshop at Calif State Univ Northridge.
Dale(engr294] (TRW / Northrop Grumman)
Dale.Hall@earthlink.net 310 374-8323
Unread 21-01-2006, 02:02
AKA: Dr. Brooks
no team (WRRF)
Al, I beg to differ...
We compared the capacity of the then new EX battery to year old ES batteries last year, and found the year old batteries to have 50% more capacity at a constant current 20 amp load. This year's milage may vary, but the batteries were quite different in performance when checked last year.
Eugene
Unread 21-01-2006, 10:49
They are right in one sense, if you stall all 4 CIMs, you won't make it anywhere near one match. However, you can also design everything very conservatively (like we did last year and EricH mentioned) and have them last forever.
Design for 1/4 stall torque and your motors and batteries will thank you.
Unread 21-01-2006, 10:56
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Eugene
There is another possibility. When we did some tests a few years ago, we found significant variation from battery to battery even among those that are nominally the same model number.
While I don't think that it is likely to be the factor that moves a robot from good to great, using the "good" batteries over the "medium" ones can't hurt.
Joe J.
Team #88, TJ2
Most influential movie on your life? FotoPlasma Chit-Chat 48 03-11-2005 21:29
This is My FIRST Life sciguy125 General Forum 1 15-09-2005 18:17
How has FIRST impacted your life? lsmith243 General Forum 9 26-05-2005 19:16
Robotics and the Meaning of Life Andrew Rudolph Chit-Chat 4 23-07-2004 19:38
A Simple note about life dddriveman Chit-Chat 14 13-05-2004 20:33
